以下示例说明了 iprb(7D) 模块中每个探测器的匿名 DTrace 启用:
# dtrace -A -m iprb dtrace: saved anonymous enabling in /kernel/drv/dtrace.conf dtrace: added forceload directives to /etc/system dtrace: run update_drv(1M) or reboot to enable changes # reboot |
重新引导后,dtrace(7D) 将在控制台上列显一条消息,指示正在启用指定的探测器:
... Copyright 1983-2003 Sun Microsystems, Inc. All rights reserved. Use is subject to license terms. NOTICE: enabling probe 0 (:iprb::) NOTICE: enabling probe 1 (dtrace:::ERROR) configuring IPv4 interfaces: iprb0. ... |
重新引导计算机后,可以通过指定带有 -a 选项的 dtrace 来使用匿名状态:
# dtrace -a
CPU ID FUNCTION:NAME
0 22954 _init:entry
0 22955 _init:return
0 22800 iprbprobe:entry
0 22934 iprb_get_dev_type:entry
0 22935 iprb_get_dev_type:return
0 22801 iprbprobe:return
0 22802 iprbattach:entry
0 22874 iprb_getprop:entry
0 22875 iprb_getprop:return
0 22870 iprb_self_test:entry
0 22871 iprb_self_test:return
0 22958 iprb_hard_reset:entry
0 22959 iprb_hard_reset:return
0 22862 iprb_get_eeprom_size:entry
0 22826 iprb_shiftout:entry
0 22828 iprb_raiseclock:entry
0 22829 iprb_raiseclock:return
以下示例仅适用于通过 iprbattach() 调用的那些函数。在编辑器中,键入以下脚本并将其保存在名为 iprb.d 的文件中。
fbt::iprbattach:entry
self->trace = 1;
fbt:::
/self->trace/
fbt::iprbattach:return
self->trace = 0;
运行以下命令清除驱动器配置文件中先前的设置,安装新的匿名跟踪请求,然后重新引导:
# dtrace -AFs iprb.d dtrace: cleaned up old anonymous enabling in /kernel/drv/dtrace.conf dtrace: cleaned up forceload directives in /etc/system dtrace: saved anonymous enabling in /kernel/drv/dtrace.conf dtrace: added forceload directives to /etc/system dtrace: run update_drv(1M) or reboot to enable changes # reboot |
重新引导后,dtrace(7D) 将在控制台上列显一条不同的消息,指示稍微不同的启用项:
... Copyright 1983-2003 Sun Microsystems, Inc. All rights reserved. Use is subject to license terms. NOTICE: enabling probe 0 (fbt::iprbattach:entry) NOTICE: enabling probe 1 (fbt:::) NOTICE: enabling probe 2 (fbt::iprbattach:return) NOTICE: enabling probe 3 (dtrace:::ERROR) configuring IPv4 interfaces: iprb0. ... |
计算机完成引导后,运行带有 -a 选项和 -e 选项的 dtrace 以使用匿名数据,然后退出。
# dtrace -ae
CPU FUNCTION
0 -> iprbattach
0 -> gld_mac_alloc
0 -> kmem_zalloc
0 -> kmem_cache_alloc
0 -> kmem_cache_alloc_debug
0 -> verify_and_copy_pattern
0 <- verify_and_copy_pattern
0 -> tsc_gethrtime
0 <- tsc_gethrtime
0 -> getpcstack
0 <- getpcstack
0 -> kmem_log_enter
0 <- kmem_log_enter
0 <- kmem_cache_alloc_debug
0 <- kmem_zalloc
0 <- gld_mac_alloc
0 -> kmem_zalloc
0 -> kmem_alloc
0 -> vmem_alloc
0 -> highbit
0 <- highbit
0 -> lowbit
0 <- lowbit
0 -> vmem_xalloc
0 -> highbit
0 <- highbit
0 -> lowbit
0 <- lowbit
0 -> segkmem_alloc
0 -> segkmem_xalloc
0 -> vmem_alloc
0 -> highbit
0 <- highbit
0 -> lowbit
0 <- lowbit
0 -> vmem_seg_alloc
0 -> highbit
0 <- highbit
0 -> highbit
0 <- highbit
0 -> vmem_seg_create
