Solaris 动态跟踪指南
示例
检查 vmstat(1M) 的以下输出:
kthr      memory            page            disk          faults      cpu
 r b w   swap  free  re  mf pi po fr de sr cd s0 — —   in   sy   cs us sy id
 0 1 0 1341844 836720 26 311 1644 0 0 0  0 216 0  0  0  797  817  697  9 10 81
 0 1 0 1341344 835300 238 934 1576 0 0 0 0 194 0  0  0  750 2795  791  7 14 79
 0 1 0 1340764 833668 24 165 1149 0 0 0  0 133 0  0  0  637  813  547  5  4 91
 0 1 0 1340420 833024 24 394 1002 0 0 0  0 130 0  0  0  621 2284  653 14  7 79
 0 1 0 1340068 831520 14 202 380 0 0  0  0 59  0  0  0  482 5688 1434 25  7 68
在以上输出中,pi 列表示调进的页数。通过 vminfo 提供器,可以详细了解这些页调进的来源,如以下示例所示:
dtrace -n pgin'{@[execname] = count()}'
dtrace: description 'pgin' matched 1 probe
^C
  xterm                                                             1
  ksh                                                               1
  ls        2
  lpstat                                                            7
  sh                                                               17
  soffice                                                          39
  javaldx                                                         103
  soffice.bin                                                    3065
以上输出表明,与 StarSuiteTM 软件关联的进程 soffice.bin 负责大多数调进页。为了更全面地了解 soffice.bin 在执行时的虚拟内存行为,可启用所有 vminfo 探测器。以下示例将在启动 StarSuite 软件时运行 dtrace(1M):
dtrace -P vminfo'/execname == "soffice.bin"/{@[probename] = count()}'
dtrace: description 'vminfo' matched 42 probes
^C
  kernel_asflt                                                      1
  fspgin                                                           10
  pgout                                                            16
  execfree                                                         16
  execpgout                                                        16
  fsfree                                                           16
  fspgout                                                          16
  anonfree                                                         16
  anonpgout                                                        16
  pgpgout                                                          16
  dfree                                                            16
  execpgin                                                         80
  prot_fault                                                       85
  maj_fault                                                        88
  pgin                                                             90
  pgpgin                                                           90
  cow_fault                                                       859
  zfod                                                           1619
  pgfrec                                                         8811
  pgrec                                                          8827
  as_fault                                                       9495
以下脚本示例提供了更多有关 StarSuite 软件在启动时的虚拟内存行为的信息:
vminfo:::maj_fault,
vminfo:::zfod,
vminfo:::as_fault
/execname == "soffice.bin" && start == 0/
	 * This is the first time that a vminfo probe has been hit; record
	 * our initial timestamp.
	start = timestamp;
vminfo:::maj_fault,
vminfo:::zfod,
vminfo:::as_fault
	 * Aggregate on the probename, and lquantize() the number of seconds
	 * since our initial timestamp.  (There are 1,000,000,000 nanoseconds
	 * in a second.)  We assume that the script will be terminated before
	 * 60 seconds elapses.
	@[probename] =
	    lquantize((timestamp - start) / 1000000000, 0, 60);
请在重新启动 StarSuite 软件时运行以上脚本。接下来,依次创建一个新的绘图、新的表示,然后关闭所有文件并退出应用程序。在运行该 D 脚本的 shell 中按 Ctrl-C 组合键。结果显示一段时间内某虚拟内存行为的情况:
# dtrace -s ./soffice.d
dtrace: script './soffice.d' matched 10 probes
^C
 maj_fault
           value  ------------- Distribution ------------- count
               7 |                                         0
               8 |@@@@@@@@@                                88
               9 |@@@@@@@@@@@@@@@@@@@@                     194
              10 |@                                        18
              11 |                                         0
              12 |                                         0
              13 |                                         2
              14 |                                         0
              15 |                                         1
              16 |@@@@@@@@                                 82
              17 |                                         0
              18 |                                         0
              19 |                                         2
              20 |                                         0
  zfod
             < 0 |                                         0
               0 |@@@@@@@                                  525
               1 |@@@@@@@@                                 605
               2 |@@                                       208
               3 |@@@                                      280
               4 |                                         4
               5 |                                         0
               6 |                                         0
               7 |                                         0
               8 |                                         44
               9 |@@                                       161
              10 |                                         2
              11 |                                         0
              12 |                                         0
              13 |                                         4
              14 |                                         0
              15 |                                         29
              16 |@@@@@@@@@@@@@@                           1048
              17 |                                         24
              18 |                                         0
              19 |                                         0
              20 |                                         1
              21 |                                         0
              22 |                                         3
              23 |                                         0
  as_fault
             < 0 |                                         0
               0 |@@@@@@@@@@@@@                            4139
               1 |@@@@@@@                                  2249
               2 |@@@@@@@                                  2402
               3 |@                                        594
               4 |                                         56
               5 |                                         0
               6 |                                         0
               7 |                                         0
               8 |                                         189
               9 |@@                                       929
              10 |                                         39
              11 |                                         0
              12 |                                         0
              13 |                                         6
              14 |                                         0
              15 |                                         297
              16 |@@@@                                     1349
              17 |                                         24
              18 |                                         0
              19 |                                         21
              20 |                                         1
              21 |                                         0
              22 |                                         92
              23 |                                         0
以上输出显示了与虚拟内存系统有关的某种 StarSuite 行为。例如,在启动新的应用程序实例之前,不会触发 maj_fault 探测器。如您所愿,StarSuite 的“热启动”并未引发新的重大故障。as_fault 输出显示了活动的初始突发传输、用户查找菜单以创建新绘图时的等待时间、另一段空闲时间,以及在用户单击新表示时,出现活动的最终突发传输。zfod 输出表明,创建新的表示对用零填充的页面产生了巨大压力,不过,该压力仅持续了一小段时间。
在此示例中,DTrace 调查的下一次重复取决于您要了解的具体方面。如果要了解用零填充的页面的请求来源,可在 zfod 启用项中聚集 ustack()。您可能希望为用零填充的页面设置阈值,并使用 stop() 破坏性操作,以便在阈值超出时停止违例进程。借助这种方法,您可以使用更多传统调试工具(如 truss(1) 或 mdb(1))。通过 vminfo 提供器,可将常规工具(如 vmstat(1M))的输出中显示的统计信息,与导致该系统行为的应用程序进行关联。
