此函数可用于获取指定控制器句柄的属性。以下列出了此函数当前已定义的属性:
typedef struct {
uint_t attr_direct_access_sizes;
uint_t attr_atomic_sizes;
size_t attr_page_size;
size_t attr_max_export_segment_size;
size_t attr_tot_export_segment_size;
ulong_t attr_max_export_segments;
size_t attr_max_import_map_size;
size_t attr_tot_import_map_size;
ulong_t attr_max_import_segments;
} rsmapi_controller_attr_t;
返回值:如果成功,则返回 0。否则返回错误值。
控制器句柄无效
地址错误
