编程接口指南
连接流套接字
以下两个示例说明启动和接受 Internet 系列流连接。
图 7–1 使用流套接字的面向连接的通信
此图形使用接受/连接和读/写功能对说明客户机与服务器之间的数据流。
以下是针对服务器的示例程序。服务器创建套接字并将名称绑定到此套接字,然后显示端口号。此程序调用 listen(3SOCKET) 将套接字标记为可以接受连接请求并初始化请求队列。此程序的其余部分为一个死循环。每次循环都接受一个新的连接并将其从队列中删除,从而创建一个新的套接字。服务器读取并显示此套接字中的消息,然后关闭此套接字。地址绑定中介绍了 in6addr_any 用法。
示例 7–1 接受 Internet 流连接(服务器)
#include <sys/types.h>
#include <sys/socket.h>
#include <netinet/in.h>
#include <netdb.h>
#include <stdio.h>
#define TRUE 1
 * This program creates a socket and then begins an infinite loop.
 * Each time through the loop it accepts a connection and prints
 * data from it. When the connection breaks, or the client closes
 * the connection, the program accepts a new connection.
main() {
    int sock, length;
    struct sockaddr_in6 server;
    int msgsock;
    char buf[1024];
    int rval;
    /* Create socket. */
    sock = socket(AF_INET6, SOCK_STREAM, 0);
    if (sock == -1) {
      perror("opening stream socket");
      exit(1);
   /* Bind socket using wildcards.*/
   bzero (&server, sizeof(server));
   server.sin6_family = AF_INET6;
   server.sin6_addr = in6addr_any;
   server.sin6_port = 0;
   if (bind(sock, (struct sockaddr *) &server, sizeof server)
         == -1) {
      perror("binding stream socket");
      exit(1);
   /* Find out assigned port number and print it out. */
   length = sizeof server;
   if (getsockname(sock,(struct sockaddr *) &server, &length)
         == -1) {
      perror("getting socket name");
      exit(1);
   printf("Socket port #%d\n", ntohs(server.sin6_port));
   /* Start accepting connections. */
   listen(sock, 5);
   do {
      msgsock = accept(sock,(struct sockaddr *) 0,(int *) 0);
      if (msgsock == -1)
         perror("accept");
      else do {
         memset(buf, 0, sizeof buf);
         if ((rval = read(msgsock,buf, sizeof(buf))) == -1)
            perror("reading stream message");
         if (rval == 0)
            printf("Ending connection\n");
         else
            /* assumes the data is printable */
            printf("-->%s\n", buf);
      } while (rval > 0);
      close(msgsock);
   } while(TRUE);
    * Since this program has an infinite loop, the socket "sock" is
    * never explicitly closed. However, all sockets are closed
    * automatically when a process is killed or terminates normally.
   exit(0);
要启动连接,示例 7–2 中的客户机程序会创建一个流套接字,然后调用 connect(3SOCKET),指定用于连接的套接字地址。如果存在目标套接字,并且接受了请求,则连接会完成。现在,程序可以发送数据。数据按顺序传送,并且没有消息边界。此连接会在任何一个套接字关闭时销毁。有关此程序中的数据表示例程(如 ntohl(3SOCKET)、ntohs(3SOCKET)、htons(3SOCKET) 以及 htonl(3XNET))的更多信息,请参见 byteorder(3SOCKET) 手册页。
示例 7–2 Internet 系列流连接(客户机)
#include <netdb.h>
#include <stdio.h>
#define DATA "Half a league, half a league . . ."
 * This program creates a socket and initiates a connection with
 * the socket given in the command line. Some data are sent over the
 * connection and then the socket is closed, ending the connection.
 * The form of the command line is: streamwrite hostname portnumber
 * Usage: pgm host port
main(int argc, char *argv[])
    int sock, errnum, h_addr_index;
    struct hostent *hp;
    char buf[1024];
    sock = socket( AF_INET6, SOCK_STREAM, 0);
    if (sock == -1) {
        exit(1);
    /* Connect socket using name specified by command line. */
    bzero (&server, sizeof (server));
    hp = getipnodebyname(argv[1], AF_INET6, AI_DEFAULT, &errnum);
 * getipnodebyname returns a structure including the network address
 * of the specified host.
    if (hp == (struct hostent *) 0) {
        fprintf(stderr, "%s: unknown host\n", argv[1]);
        exit(2);
    h_addr_index = 0;
    while (hp->h_addr_list[h_addr_index] != NULL) {
        bcopy(hp->h_addr_list[h_addr_index], &server.sin6_addr,
                    hp->h_length);
        server.sin6_port = htons(atoi(argv[2]));
        if (connect(sock, (struct sockaddr *) &server,
                    sizeof (server)) == -1) {
            if (hp->h_addr_list[++h_addr_index] != NULL) {
                /* Try next address */
                continue;
            perror("connecting stream socket");
            freehostent(hp);
            exit(1);
        break;
    freehostent(hp);
    if (write( sock, DATA, sizeof DATA) == -1)
        perror("writing on stream socket");
    close(sock);
    freehostent (hp);
    exit(0);
可以将一对一 SCTP 连接支持添加到流套接字。以下示例代码将 -p 添加到现有程序,使此程序可以指定要使用的协议。
示例 7–3 将 SCTP 支持添加到流套接字
#include <stdio.h>
#include <netdb.h>
#include <string.h>
#include <errno.h>
int
 struct protoent *proto = NULL;
 int c;
 int s;
 int protocol;
 while ((c = getopt(argc, argv, "p:")) != -1) {
  switch (c) {
  case 'p':
   proto = getprotobyname(optarg);
   if (proto == NULL) {
    fprintf(stderr, "Unknown protocol: %s\n",
        optarg);
    return (-1);
   break;
  default:
   fprintf(stderr, "Unknown option: %c\n", c);
   return (-1);
 /* Use the default protocol, which is TCP, if not specified. */
 if (proto == NULL)
  protocol = 0;
 else
  protocol = proto->p_proto;
 /* Create a IPv6 SOCK_STREAM socket of the protocol. */
 if ((s = socket(AF_INET6, SOCK_STREAM, protocol)) == -1) {
  fprintf(stderr, "Cannot create SOCK_STREAM socket of type %s: "
      "%s\n", proto != NULL ? proto->p_name : "tcp",
      strerror(errno));
  return (-1);
 printf("Success\n");
 return (0);
