本节详细介绍 SCTP 套接字的两种用法。
* Copyright 2004 Sun Microsystems, Inc. All rights reserved.
* Use is subject to license terms.
/* To enable socket features used for SCTP socket. */
#define _XPG4_2
#define __EXTENSIONS__
#include <stdio.h>
#include <string.h>
#include <sys/types.h>
#include <sys/socket.h>
#include <netinet/in.h>
#include <stdlib.h>
#include <unistd.h>
#include <pthread.h>
#include <netinet/sctp.h>
#include <netdb.h>
#define BUFLEN 1024
static void
usage(char *a0)
fprintf(stderr, "Usage: %s <addr>\n", a0);
* Read from the network.
static void
readit(void *vfdp)
int fd;
ssize_t n;
char buf[BUFLEN];
struct msghdr msg[1];
struct iovec iov[1];
struct cmsghdr *cmsg;
struct sctp_sndrcvinfo *sri;
char cbuf[sizeof (*cmsg) + sizeof (*sri)];
union sctp_notification *snp;
pthread_setcanceltype(PTHREAD_CANCEL_ASYNCHRONOUS, NULL);
fd = *(int *)vfdp;
/* Initialize the message header for receiving */
memset(msg, 0, sizeof (*msg));
msg->msg_control = cbuf;
msg->msg_controllen = sizeof (*cmsg) + sizeof (*sri);
msg->msg_flags = 0;
cmsg = (struct cmsghdr *)cbuf;
sri = (struct sctp_sndrcvinfo *)(cmsg + 1);
iov->iov_base = buf;
iov->iov_len = BUFLEN;
msg->msg_iov = iov;
msg->msg_iovlen = 1;
while ((n = recvmsg(fd, msg, 0)) > 0) {
/* Intercept notifications here */
if (msg->msg_flags & MSG_NOTIFICATION) {
snp = (union sctp_notification *)buf;
printf("[ Receive notification type %u ]\n",
snp->sn_type);
continue;
printf("[ Receive echo (%u bytes): stream = %hu, ssn = %hu, "
"flags = %hx, ppid = %u ]\n", n,
sri->sinfo_stream, sri->sinfo_ssn, sri->sinfo_flags,
sri->sinfo_ppid);
if (n < 0) {
perror("recv");
exit(1);
close(fd);
exit(0);
#define MAX_STREAM 64
static void
echo(struct sockaddr_in *addr)
int fd;
uchar_t buf[BUFLEN];
ssize_t n;
int perr;
pthread_t tid;
int ret;
struct sctp_initmsg initmsg;
struct sctp_event_subscribe events;
/* Create a one-one SCTP socket */
if ((fd = socket(AF_INET, SOCK_STREAM, IPPROTO_SCTP)) == -1) {
perror("socket");
exit(1);
* We are interested in association change events and we want
* to get sctp_sndrcvinfo in each receive.
events.sctp_association_event = 1;
events.sctp_data_io_event = 1;
ret = setsockopt(fd, IPPROTO_SCTP, SCTP_EVENTS, &events,
sizeof (events));
if (ret < 0) {
perror("setsockopt SCTP_EVENTS");
exit(1);
* Set the SCTP stream parameters to tell the other side when
* setting up the association.
memset(&initmsg, 0, sizeof(struct sctp_initmsg));
initmsg.sinit_num_ostreams = MAX_STREAM;
initmsg.sinit_max_instreams = MAX_STREAM;
initmsg.sinit_max_attempts = MAX_STREAM;
ret = setsockopt(fd, IPPROTO_SCTP, SCTP_INITMSG, &initmsg,
if (ret < 0) {
perror("setsockopt SCTP_INITMSG");
exit(1);
if (connect(fd, (struct sockaddr *)addr, sizeof (*addr)) == -1) {
perror("connect");
exit(1);
/* Initialize the message header structure for sending. */
msg->msg_iov = iov;
msg->msg_flags |= MSG_XPG4_2;
memset(cbuf, 0, sizeof (*cmsg) + sizeof (*sri));
cmsg->cmsg_len = sizeof (*cmsg) + sizeof (*sri);
cmsg->cmsg_level = IPPROTO_SCTP;
cmsg->cmsg_type = SCTP_SNDRCV;
sri->sinfo_ppid = 1;
/* Start sending to stream 0. */
sri->sinfo_stream = 0;
/* Create a thread to receive network traffic. */
perr = pthread_create(&tid, NULL, (void *(*)(void *))readit, &fd);
if (perr != 0) {
fprintf(stderr, "pthread_create: %d\n", perr);
exit(1);
/* Read from stdin and then send to the echo server. */
while ((n = read(fileno(stdin), buf, BUFLEN)) > 0) {
iov->iov_len = n;
if (sendmsg(fd, msg, 0) < 0) {
perror("sendmsg");
exit(1);
/* Send the next message to a different stream. */
sri->sinfo_stream = (sri->sinfo_stream + 1) % MAX_STREAM;
pthread_cancel(tid);
close(fd);
int
main(int argc, char **argv)
struct sockaddr_in addr[1];
struct hostent *hp;
int error;
if (argc < 2) {
usage(*argv);
exit(1);
/* Find the host to connect to. */
hp = getipnodebyname(argv[1], AF_INET, AI_DEFAULT, &error);
if (hp == NULL) {
fprintf(stderr, "host not found\n");
exit(1);
addr->sin_family = AF_INET;
addr->sin_addr.s_addr = *(ipaddr_t *)hp->h_addr_list[0];
addr->sin_port = htons(5000);
echo(addr);
return (0);
#define _XPG4_2
#include <stdio.h>
#include <string.h>
#include <arpa/inet.h>
#include <stdlib.h>
#include <unistd.h>
#define BUFLEN 1024
* Given an event notification, print out what it is.
static void
handle_event(void *buf)
struct sctp_assoc_change *sac;
struct sctp_send_failed *ssf;
struct sctp_paddr_change *spc;
struct sctp_remote_error *sre;
char addrbuf[INET6_ADDRSTRLEN];
const char *ap;
struct sockaddr_in *sin;
struct sockaddr_in6 *sin6;
snp = buf;
switch (snp->sn_header.sn_type) {
case SCTP_ASSOC_CHANGE:
sac = &snp->sn_assoc_change;
printf("^^^ assoc_change: state=%hu, error=%hu, instr=%hu "
"outstr=%hu\n", sac->sac_state, sac->sac_error,
sac->sac_inbound_streams, sac->sac_outbound_streams);
break;
case SCTP_SEND_FAILED:
ssf = &snp->sn_send_failed;
printf("^^^ sendfailed: len=%hu err=%d\n", ssf->ssf_length,
ssf->ssf_error);
break;
case SCTP_PEER_ADDR_CHANGE:
spc = &snp->sn_paddr_change;
if (spc->spc_aaddr.ss_family == AF_INET) {
sin = (struct sockaddr_in *)&spc->spc_aaddr;
ap = inet_ntop(AF_INET, &sin->sin_addr, addrbuf,
INET6_ADDRSTRLEN);
} else {
sin6 = (struct sockaddr_in6 *)&spc->spc_aaddr;
ap = inet_ntop(AF_INET6, &sin6->sin6_addr, addrbuf,
INET6_ADDRSTRLEN);
printf("^^^ intf_change: %s state=%d, error=%d\n", ap,
spc->spc_state, spc->spc_error);
break;
case SCTP_REMOTE_ERROR:
sre = &snp->sn_remote_error;
printf("^^^ remote_error: err=%hu len=%hu\n",
ntohs(sre->sre_error), ntohs(sre->sre_length));
break;
case SCTP_SHUTDOWN_EVENT:
printf("^^^ shutdown event\n");
break;
default:
printf("unknown type: %hu\n", snp->sn_header.sn_type);
break;
* Receive a message from the network.
static void *
getmsg(int fd, struct msghdr *msg, void *buf, size_t *buflen,
ssize_t *nrp, size_t cmsglen)
ssize_t nr = 0;
*nrp = 0;
msg->msg_iov = iov;
/* Loop until a whole message is received. */
for (;;) {
msg->msg_flags = MSG_XPG4_2;
msg->msg_iov->iov_len = *buflen;
msg->msg_controllen = cmsglen;
nr += recvmsg(fd, msg, 0);
if (nr <= 0) {
/* EOF or error */
*nrp = nr;
return (NULL);
/* Whole message is received, return it. */
if (msg->msg_flags & MSG_EOR) {
*nrp = nr;
return (buf);
/* Maybe we need a bigger buffer, do realloc(). */
if (*buflen == nr) {
buf = realloc(buf, *buflen * 2);
if (buf == 0) {
fprintf(stderr, "out of memory\n");
exit(1);
*buflen *= 2;
/* Set the next read offset */
iov->iov_base = (char *)buf + nr;
iov->iov_len = *buflen - nr;
* The echo server.
static void
echo(int fd)
ssize_t nr;
char *buf;
size_t buflen;
size_t cmsglen = sizeof (*cmsg) + sizeof (*sri);
/* Allocate the initial data buffer */
buflen = BUFLEN;
if ((buf = malloc(BUFLEN)) == NULL) {
exit(1);
/* Set up the msghdr structure for receiving */
msg->msg_flags = 0;
/* Wait for something to echo */
while ((buf = getmsg(fd, msg, buf, &buflen, &nr, cmsglen)) != NULL) {
handle_event(buf);
continue;
msg->msg_iov = iov;
iov->iov_len = nr;
printf("got %u bytes on stream %hu:\n", nr,
sri->sinfo_stream);
write(0, buf, nr);
/* Echo it back */
perror("sendmsg");
exit(1);
if (nr < 0) {
perror("recvmsg");
close(fd);
int
main(void)
int lfd;
int cfd;
int onoff = 1;
struct sockaddr_in sin[1];
if ((lfd = socket(AF_INET, SOCK_STREAM, IPPROTO_SCTP)) == -1) {
perror("socket");
exit(1);
sin->sin_family = AF_INET;
sin->sin_port = htons(5000);
sin->sin_addr.s_addr = INADDR_ANY;
if (bind(lfd, (struct sockaddr *)sin, sizeof (*sin)) == -1) {
perror("bind");
exit(1);
if (listen(lfd, 1) == -1) {
perror("listen");
exit(1);
(void) memset(&initmsg, 0, sizeof(struct sctp_initmsg));
initmsg.sinit_num_ostreams = 64;
initmsg.sinit_max_instreams = 64;
initmsg.sinit_max_attempts = 64;
if (setsockopt(lfd, IPPROTO_SCTP, SCTP_INITMSG, &initmsg,
sizeof(struct sctp_initmsg)) < 0) {
perror("SCTP_INITMSG");
exit (1);
/* Events to be notified for */
(void) memset(&events, 0, sizeof (events));
events.sctp_send_failure_event = 1;
events.sctp_address_event = 1;
events.sctp_peer_error_event = 1;
events.sctp_shutdown_event = 1;
/* Wait for new associations */
for (;;) {
if ((cfd = accept(lfd, NULL, 0)) == -1) {
perror("accept");
exit(1);
/* Enable ancillary data */
if (setsockopt(cfd, IPPROTO_SCTP, SCTP_EVENTS, &events,
sizeof (events)) < 0) {
exit(1);
/* Echo back any and all data */
echo(cfd);
