本节介绍 GSS-API 使用的数据类型。
OM_uint32
OM_uint32 是与平台无关的 32 位无符号整数。
包含 gss_buffer_t 指针的 gss_buffer_desc 的定义采用以下格式:
typedef struct gss_buffer_desc_struct {
size_t length;
void *value;
} gss_buffer_desc, *gss_buffer_t;
包含 gss_OID 指针的 gss_OID_desc 的定义采用以下格式:
typedef struct gss_OID_desc_struct {
OM_uint32 length;
void*elements;
} gss_OID_desc, *gss_OID;
包含 gss_OID_set 指针的 gss_OID_set_desc 的定义采用以下格式:
typedef struct gss_OID_set_desc_struct {
size_t count;
gss_OID elements;
} gss_OID_set_desc, *gss_OID_set;
gss_channel_bindings_struct 结构和gss_channel_bindings_t 指针的定义的格式如下:
typedef struct gss_channel_bindings_struct {
OM_uint32 initiator_addrtype;
gss_buffer_desc initiator_address;
OM_uint32 acceptor_addrtype;
gss_buffer_desc acceptor_address;
gss_buffer_desc application_data;
} *gss_channel_bindings_t;
