驱动程序应进一步分配和初始化此实例的传输结构。tran_hba_private 字段会设置为指向此实例的软状态结构。如果无需特殊的探测自定义,则可将 tran_tgt_probe 字段设置为 NULL 以实现缺省行为。
tran = scsi_hba_tran_alloc(dip, SCSI_HBA_CANSLEEP); isp->isp_tran = tran; isp->isp_dip = dip; tran->tran_hba_private = isp; tran->tran_tgt_private = NULL; tran->tran_tgt_init = isp_tran_tgt_init; tran->tran_tgt_probe = scsi_hba_probe; tran->tran_tgt_free = (void (*)())NULL; tran->tran_start = isp_scsi_start; tran->tran_abort = isp_scsi_abort; tran->tran_reset = isp_scsi_reset; tran->tran_getcap = isp_scsi_getcap; tran->tran_setcap = isp_scsi_setcap; tran->tran_init_pkt = isp_scsi_init_pkt; tran->tran_destroy_pkt = isp_scsi_destroy_pkt; tran->tran_dmafree = isp_scsi_dmafree; tran->tran_sync_pkt = isp_scsi_sync_pkt; tran->tran_reset_notify = isp_scsi_reset_notify; tran->tran_bus_quiesce = isp_tran_bus_quiesce tran->tran_bus_unquiesce = isp_tran_bus_unquiesce tran->tran_bus_reset = isp_tran_bus_reset tran->tran_interconnect_type = isp_tran_interconnect_type
