系统管理指南:名称和目录服务(DNS、NIS 和 LDAP)
idsconfig 设置示例
本节提供了一个简单的 idsconfig 设置示例,该示例没有对缺省值进行太多修改。修改客户机配置文件最复杂的方法就是创建 SSD。有关详细讨论,请参阅使用服务搜索描述符来修改客户机对各个服务的访问。
提示符后面的回车符表示可通过按 Enter 来接受 [缺省值]。
注意 –
对于摘要屏幕上留空的任何参数将不进行设置。
在 idsconfig 完成了目录的设置之后,您需要在服务器上运行指定的命令,才能完成服务器的设置过程,服务器此时即可为客户机提供服务。
实例 11–1 对于 Example, Inc. 网络运行 idsconfig
# usr/lib/ldap/idsconfig
It is strongly recommended that you BACKUP the directory server
before running idsconfig.
Hit Ctrl-C at any time before the final confirmation to exit.
Do you wish to continue with server setup (y/n/h)? [n] Y
Enter the directory server's hostname to setup: myserver
Enter the Directory Server's port number (h=help): [389]
Enter the directory manager DN: [cn=Directory Manager]
Enter passwd for cn=Directory Manager :
Enter the domainname to be served (h=help): [west.example.com]
Enter LDAP Base DN (h=help): [dc=west,dc=example,dc=com]
Enter the profile name (h=help): [default] WestUserProfile
Default server list (h=help): [192.168.0.1]
Preferred server list (h=help):
Choose desired search scope (one, sub, h=help):  [one]
The following are the supported credential levels:
  1  anonymous
  2  proxy
  3  proxy anonymous
Choose Credential level [h=help]: [1] 2
The following are the supported Authentication Methods:
  1  none
  2  simple
  3  sasl/DIGEST-MD5
  4  tls:simple
  5  tls:sasl/DIGEST-MD5
Choose Authentication Method (h=help): [1] 2
Current authenticationMethod: simple
Do you want to add another Authentication Method? N
Do you want the clients to follow referrals (y/n/h)? [n] N
Do you want to modify the server timelimit value (y/n/h)? [n] Y
Enter the server time limit (current=3600): [-1]
Do you want to modify the server sizelimit value (y/n/h)? [n] Y
Enter the server size limit (current=2000): [-1]
Do you want to store passwords in "crypt" format (y/n/h)? [n] Y
Do you want to setup a Service Authentication Methods (y/n/h)? [n]
Client search time limit in seconds (h=help): [30]
Profile Time To Live in seconds (h=help): [43200]
Bind time limit in seconds (h=help): [10]
Do you wish to setup Service Search Descriptors (y/n/h)? [n]
              Summary of Configuration
  1  Domain to serve               : west.example.com
  2  Base DN to setup              : dc=west,dc=example,dc=com
  3  Profile name to create        : WestUserProfile
  4  Default Server List           : 192.168.0.1
  5  Preferred Server List         :
  6  Default Search Scope          : one
  7  Credential Level              : proxy
  8  Authentication Method         : simple
  9  Enable Follow Referrals       : FALSE
 10  Server Time Limit             : -1
 11  Server Size Limit             : -1
 12  Enable crypt password storage : TRUE
 13  Service Auth Method pam_ldap  :
 14  Service Auth Method keyserv   :
 15  Service Auth Method passwd-cmd:
 16  Search Time Limit             : 30
 17  Profile Time to Live          : 43200
 18  Bind Limit                    : 10
 19  Service Search Descriptors Menu
Enter config value to change: (1-19 0=commit changes) [0]
Enter DN for proxy agent:[cn=proxyagent,ou=profile,dc=west,dc=example,dc=com]
Enter passwd for proxyagent:
Re-enter passwd:
WARNING: About to start committing changes. (y=continue, n=EXIT) Y
1. Changed timelimit to -1 in cn=config.
2. Changed sizelimit to -1 in cn=config.
3. Changed passwordstoragescheme to "crypt" in cn=config.
4. Schema attributes have been updated.
5. Schema objectclass definitions have been added.
6. Created DN component dc=west.
7. NisDomainObject added to dc=west,dc=example,dc=com.
8. Top level "ou" containers complete.
9. automount maps: auto_home auto_direct auto_master auto_shared processed.
10. ACI for dc=west,dc=example,dc=com modified to disable self modify.
11. Add of VLV Access Control Information (ACI).
12. Proxy Agent cn=proxyagent,ou=profile,dc=west,dc=example,dc=com added.
13. Give cn=proxyagent,ou=profile,dc=west,dc=example,dc=com read permission for
password.
14. Generated client profile and loaded on server.
15. Processing eq,pres indexes:
      uidNumber (eq,pres)   Finished indexing.
      ipNetworkNumber (eq,pres)   Finished indexing.
      gidnumber (eq,pres)   Finished indexing.
      oncrpcnumber (eq,pres)   Finished indexing.
      automountKey (eq,pres)   Finished indexing.
16. Processing eq,pres,sub indexes:
      ipHostNumber (eq,pres,sub)   Finished indexing.
      membernisnetgroup (eq,pres,sub)   Finished indexing.
      nisnetgrouptriple (eq,pres,sub)   Finished indexing.
17. Processing VLV indexes:
      west.example.com.getgrent vlv_index     Entry created
      west.example.com.gethostent vlv_index   Entry created
      west.example.com.getnetent vlv_index    Entry created
      west.example.com.getpwent vlv_index     Entry created
      west.example.com.getrpcent vlv_index    Entry created
      west.example.com.getspent vlv_index     Entry created
      west.example.com.getauhoent vlv_index   Entry created
      west.example.com.getsoluent vlv_index   Entry created
      west.example.com.getauduent vlv_index   Entry created
      west.example.com.getauthent vlv_index   Entry created
      west.example.com.getexecent vlv_index   Entry created
      west.example.com.getprofent vlv_index   Entry created
      west.example.com.getmailent vlv_index   Entry created
      west.example.com.getbootent vlv_index   Entry created
      west.example.com.getethent vlv_index    Entry created
      west.example.com.getngrpent vlv_index   Entry created
      west.example.com.getipnent vlv_index    Entry created
      west.example.com.getmaskent vlv_index   Entry created
      west.example.com.getprent vlv_index     Entry created
      west.example.com.getip4ent vlv_index    Entry created
      west.example.com.getip6ent vlv_index    Entry created
idsconfig: Setup of myserver is complete.
Note: idsconfig has created entries for VLV indexes.  Use the
      directoryserver(1m) script on myserver to stop
      the server and then enter the following vlvindex
      sub-commands to create the actual VLV indexes:
  directoryserver -s myserver vlvindex -n userRoot -T west.example.com.getgrent
  directoryserver -s myserver vlvindex -n userRoot -T west.example.com.gethostent
  directoryserver -s myserver vlvindex -n userRoot -T west.example.com.getnetent
  directoryserver -s myserver vlvindex -n userRoot -T west.example.com.getpwent
  directoryserver -s myserver vlvindex -n userRoot -T west.example.com.getrpcent
  directoryserver -s myserver vlvindex -n userRoot -T west.example.com.getspent
  directoryserver -s myserver vlvindex -n userRoot -T west.example.com.getauhoent
  directoryserver -s myserver vlvindex -n userRoot -T west.example.com.getsoluent
  directoryserver -s myserver vlvindex -n userRoot -T west.example.com.getauduent
  directoryserver -s myserver vlvindex -n userRoot -T west.example.com.getauthent
  directoryserver -s myserver vlvindex -n userRoot -T west.example.com.getexecent
  directoryserver -s myserver vlvindex -n userRoot -T west.example.com.getprofent
  directoryserver -s myserver vlvindex -n userRoot -T west.example.com.getmailent
  directoryserver -s myserver vlvindex -n userRoot -T west.example.com.getbootent
  directoryserver -s myserver vlvindex -n userRoot -T west.example.com.getethent
  directoryserver -s myserver vlvindex -n userRoot -T west.example.com.getngrpent
  directoryserver -s myserver vlvindex -n userRoot -T west.example.com.getipnent
  directoryserver -s myserver vlvindex -n userRoot -T west.example.com.getmaskent
  directoryserver -s myserver vlvindex -n userRoot -T west.example.com.getprent
  directoryserver -s myserver vlvindex -n userRoot -T west.example.com.getip4ent
  directoryserver -s myserver vlvindex -n userRoot -T west.example.com.getip6ent
