如果不能使用库提供器的某些加密机制,则可以删除所选机制。此过程使用 pkcs11_softtoken 库中的 DES 机制为例。
要创建包括加密管理权限配置文件的角色并将该角色指定给用户,请参见示例 9–7。
% cryptoadm list -m provider=/usr/lib/security/'$ISA'/pkcs11_softtoken.so /usr/lib/security/$ISA/pkcs11_softtoken.so: CKM_DES_CBC,CKM_DES_CBC_PAD,CKM_DES_ECB,CKM_DES_KEY_GEN, CKM_DES3_CBC,CKM_DES3_CBC_PAD,CKM_DES3_ECB,CKM_DES3_KEY_GEN, CKM_AES_CBC,CKM_AES_CBC_PAD,CKM_AES_ECB,CKM_AES_KEY_GEN, … |
$ cryptoadm list -p user-level providers: ===================== … /usr/lib/security/$ISA/pkcs11_softtoken.so: all mechanisms are enabled. random is enabled. … |
禁用无法使用的机制。
$ cryptoadm disable provider=/usr/lib/security/'$ISA'/pkcs11_softtoken.so \ > mechanism=CKM_DES_CBC,CKM_DES_CBC_PAD,CKM_DES_ECB |
列出可使用的机制。
$ cryptoadm list -p provider=/usr/lib/security/'$ISA'/pkcs11_softtoken.so /usr/lib/security/$ISA/pkcs11_softtoken.so: all mechanisms are enabled, except CKM_DES_ECB,CKM_DES_CBC_PAD,CKM_DES_CBC. random is enabled. |
在以下示例中,将使禁用的 DES 机制再次可用。
$ cryptoadm list -m provider=/usr/lib/security/'$ISA'/pkcs11_softtoken.so /usr/lib/security/$ISA/pkcs11_softtoken.so: CKM_DES_CBC,CKM_DES_CBC_PAD,CKM_DES_ECB,CKM_DES_KEY_GEN, CKM_DES3_CBC,CKM_DES3_CBC_PAD,CKM_DES3_ECB,CKM_DES3_KEY_GEN, … $ cryptoadm list -p provider=/usr/lib/security/'$ISA'/pkcs11_softtoken.so /usr/lib/security/$ISA/pkcs11_softtoken.so: all mechanisms are enabled, except CKM_DES_ECB,CKM_DES_CBC_PAD,CKM_DES_CBC. random is enabled. $ cryptoadm enable provider=/usr/lib/security/'$ISA'/pkcs11_softtoken.so \ > mechanism=CKM_DES_ECB $ cryptoadm list -p provider=/usr/lib/security/'$ISA'/pkcs11_softtoken.so /usr/lib/security/$ISA/pkcs11_softtoken.so: all mechanisms are enabled, except CKM_DES_CBC_PAD,CKM_DES_CBC. random is enabled. |
$ cryptoadm enable provider=/usr/lib/security/'$ISA'/pkcs11_softtoken.so all $ cryptoadm list -p provider=/usr/lib/security/'$ISA'/pkcs11_softtoken.so /usr/lib/security/$ISA/pkcs11_softtoken.so: all mechanisms are enabled. random is enabled. |
$ cryptoadm uninstall provider=/opt/SUNWconn/lib/'$ISA'/libpkcs11.so.1
$ cryptoadm list
/usr/lib/security/$ISA/pkcs11_kernel.so
kernel software providers:
