此过程使用 kclient 安装实用程序而不是使用安装配置文件。
以下输出给出了运行 kclient 命令的结果。
client# /usr/sbin/kclient
Starting client setup
Do you want to use DNS for kerberos lookups ? [y/n]: n
No action performed.
Enter the Kerberos realm: EXAMPLE.COM
Specify the KDC hostname for the above realm: kdc1.example.com
Setting up /etc/krb5/krb5.conf.
Enter the krb5 administrative principal to be used: clntconfig/admin
Obtaining TGT for clntconfig/admin ...
Password for clntconfig/admin@EXAMPLE.COM: <Type the password>
Do you plan on doing Kerberized nfs ? [y/n]: n
host/client.example.com entry ADDED to KDC database.
host/client.example.com entry ADDED to keytab.
Do you want to copy over the master krb5.conf file ? [y/n]: y
Enter the pathname of the file to be copied: \
/net/kdc1.example.com/export/install/krb5.conf
Copied /net/kdc1.example.com/export/install/krb5.conf.
Setup COMPLETE !
