Solaris 可调参数参考手册
不支持的参数或已过时的参数
不支持 priority_paging 和 cachefree
在 Solaris 9 发行版中,不支持 priority_paging 和 cachefree 可调参数。这些参数已被增强的文件系统高速缓存体系结构所代替,此体系结构实现与优先级分页类似的分页策略,但这些分页策略始终处于启用状态。尝试在 /etc/system 文件中设置这些参数时,将导致引导时警告,例如:
sorry, variable 'priority_paging' is not defined in the 'kernel'
sorry, variable 'cachefree' is not defined in the 'kernel'
已对包含 /etc/system 文件的 SUNWcsr 软件包进行了修改,以禁止包含 priority_paging 或 cachefree 可调参数。如果升级到 Solaris 9 发行版或添加 SUNWcsr 软件包,并且 /etc/system 文件包含 priority_paging 或 cachefree 参数,则会出现以下情况:
  1. 如果在 /etc/system 文件中设置 priority_paging 或 cachefree 参数,则会显示以下消息:
    /etc/system has been modified since it contains references to priority
    paging tunables. Please review the changed file.
  2. 在 /etc/system 文件的任何设置 priority_paging 或 cachefree 的行前面插入注释。例如,如果将 priority_paging 设置为 1,则会在包含 priority_paging 值的行前面插入以下行:
*NOTE: As of Solaris 9, priority paging is unnecessary and has been removed.
* Since references to priority paging-related tunables will now result in
* boot-time warnings, the assignment below has been commented out. For more
* details,see the Solaris 9 Release Notes,or the "Solaris Tunable Parameters
* Reference Manual".
System V 共享内存
以下参数已过时:
