Solaris Volume Manager 管理指南
Procedure如何检查状态数据库副本的状态
  1. 成为超级用户。
  2. 要检查状态数据库副本的状态,请使用以下方法之一:
    • 从 Solaris Management Console 中增强的存储工具中,打开“状态数据库副本”节点以查看现有的全部状态数据库副本。有关更多信息,请参见联机帮助。
    • 使用 metadb 命令查看状态数据库副本的状态。添加 -i 选项以显示状态标志的说明,如以下示例中所示。请参见 metadb(1M)。
示例 7–4 检查所有状态数据库副本的状态
# metadb -i
        flags           first blk       block count
     a m  p  luo        16              8192            /dev/dsk/c0t0d0s7
     a    p  luo        8208            8192            /dev/dsk/c0t0d0s7
     a    p  luo        16400           8192            /dev/dsk/c0t0d0s7
     a    p  luo        16              8192            /dev/dsk/c1t3d0s1
      W   p  l          16              8192            /dev/dsk/c2t3d0s1
     a    p  luo        16              8192            /dev/dsk/c1t1d0s3
     a    p  luo        8208            8192            /dev/dsk/c1t1d0s3
     a    p  luo        16400           8192            /dev/dsk/c1t1d0s3
 r - replica does not have device relocation information
 o - replica active prior to last mddb configuration change
 u - replica is up to date
 l - locator for this replica was read successfully
 c - replica's location was in /etc/lvm/mddb.cf
 p - replica's location was patched in kernel
 m - replica is master, this is replica selected as input
 W - replica has device write errors
 a - replica is active, commits are occurring to this replica
 M - replica had problem with master blocks
 D - replica had problem with data blocks
 F - replica had format problems
 S - replica is too small to hold current data base
 R - replica had device read errors
所有标志的说明后跟相应的状态。设备名称前面的字符表示状态。大写字母表示处于问题状态,小写字母表示处于“正常”状态。
