Solaris 10 8/07 Installation Guide: Solaris Live Upgrade and Upgrade Planning
Adding or Changing a Description Associated With a Boot Environment Name
You can associate a description with a boot environment name. The description never replaces the name. Although a boot environment name is restricted in length and characters, the description can be of any length and of any content. The description can be simple text or as complex as a gif file. You can create this description at these times:
For more information about using the -A option with lucreate
To Create a Boot Environment for the First Time
For more information about creating the description after the boot environment has been created
ludesc(1M)
ProcedureTo Add or Change a Description for a Boot Environment Name With Text
  1. Become superuser or assume an equivalent role.
    Roles contain authorizations and privileged commands. For more information about roles, see Configuring RBAC (Task Map) in System Administration Guide: Security Services.
  2. Type:
    # /usr/sbin/ludesc -n  BE_name 'BE_description'
    Specifies the boot environment name and the new description to be associated with the name
Example 7–5 Adding a Description to a Boot Environment Name With Text
In this example, a boot environment description is added to a boot environment that is named second_disk. The description is text that is enclosed in single quotes.
# /usr/sbin/ludesc -n second_disk 'Solaris 10 8/07 test build'
ProcedureTo Add or Change a Description for a Boot Environment Name With a File
  2. Type:
    # /usr/sbin/ludesc -n BE_name -f file_name
    -n BE_name
    file_name
    Specifies the file to be associated with a boot environment name
Example 7–6 Adding a Description to a Boot Environment Name With a File
In this example, a boot environment description is added to a boot environment that is named second_disk. The description is contained in a gif file.
# /usr/sbin/ludesc -n second_disk -f rose.gif
ProcedureTo Determine a Boot Environment Name From a Text Description
The following command returns the name of the boot environment associated with the specified description.
  2. Type:
    # /usr/sbin/ludesc -A 'BE_description'
    -A 'BE_description'
    Specifies the description to be associated with the boot environment name.
Example 7–7 Determining a Boot Environment Name From a Description
In this example, the name of the boot environment, second_disk, is determined by using the -A option with the description.
# /usr/sbin/ludesc -A  'Solaris 10 8/07 test build'
 second_disk
ProcedureTo Determine a Boot Environment Name From a Description in a File
The following command displays the boot environment's name that is associated with a file. The file contains the description of the boot environment.
  2. Type:
    # /usr/sbin/ludesc -f  file_name
    -f file_name
    Specifies the name of the file that contains the description of the boot environment.
Example 7–8 Determining a Boot Environment Name From a Description in a File
In this example, the name of the boot environment, second_disk, is determined by using the -f option and the name of the file that contains the description.
# /usr/sbin/ludesc -f rose.gif
second_disk
ProcedureTo Determine a Boot Environment Description From a Name
This procedure displays the description of the boot environment that is named in the command.
  2. Type:
    -n BE_name
    Specifies the boot environment name.
Example 7–9 Determining a Boot Environment Description From a Name
In this example, the description is determined by using the -n option with the boot environment name.
