Solaris 10 8/07 Installation Guide: Solaris Flash Archives (Creation and Installation)
ProcedureTo Install the Master System for an Initial Installation
  1. Identify the system configuration that you want to install.
  2. With the use of the Solaris installation programs, install the Solaris OS on the master system. For a discussion of the different installation program , refer to Choosing a Solaris Installation Method in Solaris 10 8/07 Installation Guide: Planning for Installation and Upgrade.
  3. Customize your Solaris installation in any of the following ways:
    • Delete software.
    • Add software.
    • Modify configuration files.
    • Add support for peripheral devices on the clone system.
    You can create custom scripts or use the flarcreate command to create the archive.
