Solaris 10 10/08 Installation Guide: Network-Based Installations
ProcedureTo Install Keys in the Client OBP
You can assign key values to OBP network boot argument variables before you boot the client. These keys can then be used for future WAN boot installations of the client.
To install keys in the client OBP, follow these steps.
If you want to assign key values to OBP network boot argument variables, follow these steps.
  1. Assume the same user role as the web server user on the WAN boot server.
  2. Display the key value for each client key.
    # wanbootutil keygen -d -c -o net=net-ip,cid=client-ID,type=key-type
    net-ip
    The IP address of the client's subnet.
    client-ID
    The ID of the client you want to install. The client ID can be a user-defined ID or the DHCP client ID.
    key-type
    The key type you want to install on the client. Valid key types are 3des, aes, or sha1.
    The hexadecimal value for the key is displayed.
  3. Repeat the previous step for each type of client key you want to install.
  4. Bring the client system to run level 0.
    # init 0
    The ok prompt is displayed.
  5. At the client ok prompt, set the value for the hashing key.
    ok set-security-key wanboot-hmac-sha1 key-value
    set-security-key
    Installs the key on the client
    wanboot-hmac-sha1
    Instructs OBP to install a HMAC SHA1 hashing key
    key-value
    Specifies the hexadecimal string that is displayed in Step 2.
    The HMAC SHA1 hashing key is installed in the client OBP.
  6. At the client ok prompt, install the encryption key.
    ok set-security-key wanboot-3des key-value
    set-security-key
    wanboot-3des
    Instructs OBP to install a 3DES encryption key. If you want to use an AES encryption key, set this value to wanboot-aes.
    key-value
    Specifies the hexadecimal string that represents the encryption key.
    The 3DES encryption key is installed in the client OBP.
    After you install the keys, you are ready to install the client. See Installing the Client for instructions about how to install the client system.
  7. (Optional) Verify that the keys are set in the client OBP.
    ok list-security-keys
    Security Keys:
             wanboot-hmac-sha1
             wanboot-3des
  8. (Optional) If you need to delete a key, type the following command.
    ok set-security-key key-type
    key-type
    Specifies the type of key you need to delete. Use the value wanboot-hmac-sha1, wanboot-3des, or wanboot-aes.
Example 13–2 Installing Keys in the Client OBP
The following example shows how to install a hashing key and an encryption key in the client OBP.
Display the key values on the WAN boot server.
# wanbootutil keygen -d -c -o net=192.168.198.0,cid=010003BA152A42,type=sha1
b482aaab82cb8d5631e16d51478c90079cc1d463
# wanbootutil keygen -d -c -o net=192.168.198.0,cid=010003BA152A42,type=3des
9ebc7a57f240e97c9b9401e9d3ae9b292943d3c143d07f04
The previous example uses the following information.
net=192.168.198.0
Specifies the IP address of the client's subnet
cid=010003BA152A42
Specifies the client's ID
Specifies the value of the client's HMAC SHA1 hashing key
Specifies the value of the client's 3DES encryption key
If you use an AES encryption key in your installation, change wanboot-3des to wanboot-aes to display the encryption key value.
Install the keys on the client system.
ok set-security-key wanboot-hmac-sha1 b482aaab82cb8d5631e16d51478c90079cc1d463
ok set-security-key wanboot-3des 9ebc7a57f240e97c9b9401e9d3ae9b292943d3c143d07f04
The previous commands perform the following tasks.
Continuing the WAN Boot Installation
After you install keys on your client, you are ready to install the client over the WAN. For instructions, see Installing the Client.
See Also
For more information about how to display key values, see the man page wanbootutil(1M).
