Solaris 10 10/08 Installation Guide: Solaris Flash Archives (Creation and Installation)
Chapter 5 Solaris Flash (Reference)
This chapter provides a description of Solaris Flash sections,
keywords, and keyword values. Also, the chapter describes the flar command
options.
For
limitations when creating or installing a Solaris Flash archive, see Table 2–1.
Solaris Flash Archive Section Descriptions
Each Solaris Flash archive is grouped into sections. Some sections
are generated by the Solaris Flash software and need no input from you.
Some sections require input or optionally allow you to add information. The
following table describes each section.
Table 5–1 Flash Archive
Sections
Section Name
Description
Required by Archive?
Requires Input From User?
Archive cookie
The first section
contains a cookie that identifies the file as a Solaris Flash archive.
The deployment code uses the cookie for identification and validation purposes.
The cookie must be present for an archive to be valid.
Yes
No
Archive identification
The second
section contains keywords with values that provide identification information
about the archive. The software generates some information such as the following:
You are required to specify a name for the Solaris Flash archive.
Other information that you can specify about the archive includes the following:
The author of the archive
The date that the archive was created
The name of the master system that you used to create the
archive
For a list of keywords that describe the archive, see Keywords for the Archive Identification Section.
Yes
Content is generated by both user and the software
Manifest
A section of a Solaris
Flash archive that is used to validate a clone system. The manifest section
lists the files on a system to be retained, added to, or deleted from the
clone system. The installation fails if the files do not match the expected
file set. This section is informational only. The section lists the files
in an internal format and cannot be used for scripting.
You can exclude this section by creating the differential archive with
the flarcreate -M option. Because no validation
of the archive occurs, excluding this section is not recommended.
No
No
Predeployment, Postdeployment, Reboot
This section contains internal information that the flash software
uses before and after installing an OS image. Any customization scripts that
you have provided are stored in this section.
Yes
No
Summary
messages about the archive creation and records the activities of predeployment
scripts.
Yes
User-defined
This section follows
the archive-identification section. The archive can contain zero or more
user-defined sections. These sections are not processed by the archive extraction
code. These sections are retrieved separately and can be used for content
descriptions.
No
Yes
Archive files
The archive files
section contains the files that have been gathered from the master system
in binary data. This section begins with section_begin=archive,
but it does not have an ending section boundary.
Yes
No
Solaris Flash Keywords
Solaris Flash keywords are like custom JumpStart keywords. They
define elements of the installation. Each keyword is a command that controls
one aspect of how the Solaris Flash software installs the software on
a clone system.
Use the following
guidelines to format keywords and values:
Keywords and values are separated by a single equal sign with
only one pair per line
Keywords are case insensitive
Individual lines can be any length
General Keywords
Each Solaris Flash archive section is defined by the section_begin and section_end keywords. For example, the
archive files section includes a section_begin keyword,
though with a different value. User-defined archive sections are delimited
by section_begin and section_end
keywords, with values appropriate to each section. The values for the section_begin and section_end keywords are described in the
following table.
Table 5–2 Values for
section_begin and
section_end Keywords
Archive Section
Value for section_begin and section_end keywords
Archive cookie
cookie – This section is not delimited by the section_begin and section_end keywords.
identification
User-defined sections
section_name – An example of a section_name keyword is X-user_section_1.
Archive files
archive
The following tables describe the keywords for use in the archive identification
section and the values you can define for them.
Every section uses the keywords in Table 5–3 to delimit each section.
Table 5–3 Archive Identification
Section Keywords: General Keywords
Keywords
Value Definitions
Value
Required
section_begin
section_end
These keywords are used to delimit sections in the archive and are not
limited exclusively to the archive identification section. For a description
of these keywords, see General Keywords.
Text
Yes
The following keywords, used in the archive-identification section,
describe the contents of the archive files section.
Table 5–4 Archive Identification
Section Keywords: Contents of Archive Files Section
Keywords
Value Definitions
Value
Required
archive_id (optional)
This keyword uniquely describes the contents of the archive. This
value is used by the installation software only to validate the contents of
the archive during archive installation. If the keyword is not present, no
integrity check is performed.
For example, the archive_id keyword might be FlAsH-ARcHive-2.0.
Text
No
files_archived_method
This keyword describes the archive method that is used in the files
section.
If this keyword is not present, the files section is assumed
to be in cpio format with ASCII headers. This format
is the cpio -c option.
If this keyword is present, it has one of
the following values:
cpio – The archive format in the
files section is cpio with ASCII headers.
pax – The archive format in the files
section is pax with extended tar interchange
format. The pax utility enables archiving and extracting
files that are greater than 4 GB.
If the files_compressed_method is present, the compression
method is applied to the archive file that is created by the archive method.
Text
No
files_archived_size
This keyword value is the size of the archived files section in bytes.
Numeric
No
files_compress_method
This keyword describes the compression algorithm that is used on the
files section.
If the keyword is present, it can have one of the following
values.
If this keyword is not present, the archive files section
is assumed to be uncompressed.
The compression method that is indicated by this keyword is applied
to the archive file created by the archive method indicated by the files_archived_method keyword.
Text
No
files_unarchived_size
This keyword defines the cumulative size in bytes of the extracted archive.
The value is used for file-system size verification.
Numeric
No
The following keywords provide descriptive information about the entire
archive. These keywords are generally used to assist you in archive selection
and to aid in archive management. These keywords are all optional and are
used to help you to distinguish between individual archives. You use options
for the flarcreate command to include these keywords. For
details, see Example 3–9.
Table 5–5 Archive Identification
Section Keywords: User Describes the Archive
Keywords
Value Definitions
Value
Required
creation_date
This keyword value is a textual timestamp that represents the time that
you created the archive.
You can use the flarcreate command with
the -i option to create the date.
If you do not specify a creation date with the flarcreate command, the default date is set in Greenwich mean time (GMT).
The value must be in ISO-8601 complete basic calendar format
without the time designator (ISO-8601,§5.4.1(a)). The format is CCYYMMDDhhmmss. For example, 20000131221409 represents January
31, 2000, 10:14:09 p.m.
Text
No
creation_master
This keyword value is the name of the master system you used to create
the archive. You can use the flarcreate -m option
to create this value. If you do not specify a value, the value is taken from
the uname -n command.
Text
No
content_name
This keyword identifies the archive. The value is generated from the flarcreate -n option. Follow these guidelines when
you create this value:
Text
Yes
content_type
This keyword value specifies a category for the archive. You use the flarcreate -T option to generate the value.
Text
No
content_description
The keyword value describes the contents of the archive. The value
of this keyword has no length limit. You use the flarcreate -E option to create this value.
Text
No
content_author
This keyword value identifies the creator of the archive. You use the flarcreate-a option to create this value. Suggested
values include the full name of the creator and the creator's email address.
Text
No
content_architectures
This keyword value is a comma-separated list of the kernel architectures
that the archive supports.
If the keyword is present, the installation software validates
the kernel architecture of the clone system against the list of architectures
that the archive supports. The installation fails if the archive does not
support the kernel architecture of the clone system.
If the keyword is not present, the installation software
does not validate the architecture of the clone system.
Text list
No
The following keywords also describe the entire archive. By default,
the values are filled in by uname when the flash archive
is created. If you create a flash archive in which the root directory is
not /, the archive software inserts the string UNKNOWN
for the keywords. The exceptions are the creation_node, creation_release, and creation_os_name keywords.
For creation_node, the software uses the
contents of the nodename file.
For creation_release and creation_os_name, the software attempts to use the contents of root directory /var/sadm/system/admin/INST_RELEASE. If the software is unsuccessful
in reading this file, it assigns the value UNKNOWN.
Regardless of their sources, you cannot override the values of these
keywords.
Table 5–6 Archive Identification Section
Keywords: Software Describes the Archive
Keyword
Value
creation_node
The return from uname -n
creation_hardware_class
The return from uname -m
creation_platform
The return from uname -i
creation_processor
The return from uname -p
creation_release
The return from uname -r
creation_os_name
The return from uname -s
creation_os_version
The return from uname -v
User-Defined Section Keywords
In addition to the keywords that
are defined by the Solaris Flash archive, you can define other keywords.
The Solaris Flash archive ignores user-defined keywords, but you can
provide scripts or programs that process the archive identification section
and use user-defined keywords. Use the following format when creating user-defined
keywords:
Begin the keyword name with an X.
Create the keyword with any characters other than linefeeds,
equal signs, and null characters.
Suggested naming conventions for user-defined keywords
include the underscore-delimited descriptive method used for the predefined
keywords. Another convention is a federated convention similar to the
naming of Java packages.
For example, X-department is a valid name for a user-defined
keyword.
For an example of using options to include user-defined keywords in
the archive identification section, see Example 3–9.
Solaris Flash flar Command
Use the Solaris Flash flar command to create
a Solaris Flash archive and administer the archive.
flar Command
You can use the flar command with the following options:
flarcreate creates an archive
flar combine merges two archives
flar split breaks an archive into sections
flar info checks the structure of an archive
Use the flarcreate command to create a Solaris Flash archive
from a master system. You can use this command when the master system is running
in multiuser mode or single-user mode. You can also use flarcreate when
the master system is booted from the following media.
The master system should be in as stable a state as possible when you
create a Solaris Flash archive.
Note – You can create a Solaris Flash archive by using either of
these command options:
The syntax of the command is as follows:
flarcreate -n archive_name [-R root] [-A unchanged_master_image_dir] [-H][-I][-M][[-S]-c][-t [-p posn] [-b blocksize]][-i date][-u section ...][-m master][-f [list_filename| -] [-F][-a author][-e descr|-E descr_file][-L pax] [-T type][-U key=val ...][-x exclude_dir/filename] [-y include_dir/filename] [-z list_filename] [-X list_filename]path/filename
flar combine [-d dir]
[-u section...] [-t [-p posn] path/filename
flar split [-d dir]
[-u section...] [-f]
[-S section] [-t [-p posn] path/filename
flar info [-l] [-k keyword] [-t [-p posn] path/filename
In the previous command lines, path is the
directory in which you want the archive file to be saved. filename is
the name of the archive file. If you do not specify a path, flarcreate saves
the archive file in the current directory.
Table 5–7 Command-Line Options for the
flar Command
Option
Description
Required Options
-n archive_name
The value of this flag is the name of the archive. The archive_name you specify is the value of the content_name keyword.
Option for Compression
-c
Compresses the archive by using compress(1).
Options for Directories and Sizes
-R root
Creates the archive from the file system tree that begins at the file
system specified by root. If you do not specify
this option, flarcreate creates an archive from a file
system that begins at the root (/) file system.
-S
Omits sizing information in the archive.
-H
Does not generate the hash identifier.
Options for Creating a Differential Archive
Creates a differential archive by comparing a new system image with
the image that is specified by the unchanged_master_image_dir argument.
By default, the new system image is root (/). You can
change the default with the -R option. unchanged_master_image_dir is a directory where the unchanged master system image is stored
or mounted through UFS, NFS, or lumount.
You can modify the effects of file selection for a differential archive
by using the options for contents selection described in the next section
of the table.
-M
Excludes the manifest file. When you use this option, no validation
occurs on the differential archive. When creating a differential archive, flarcreate creates a long list of the files in the system that are
unchanged, are changed, and are to be deleted from the archive. This list
is stored in the manifest section of the archive. When the differential archive
is deployed, the software uses this list to perform a file-by-file check,
ensuring the integrity of the clone system. Use of this option avoids such
a check and saves the space that is used by the manifest section in a differential
archive. However, you must consider the savings in time and disk space against
the loss of an integrity check upon installation. Because no validation occurs,
avoid using this option.
Options for Contents Selection
Caution – Use the flarcreate file-exclusion options
with caution. If you exclude some directories, others that you were unaware
of might be left in the archive, such as system configuration files. The system
would then be inconsistent and the installation would not work. Excluding
directories and files is best used with data that can easily be removed without
disrupting the system, such as large data files.
Adds to the archive those files and directories that are specified on
the command line. This option is used when you have excluded a directory,
but want to restore individual subdirectories or files.
include_dir/filename is the name of the subdirectory
or file to be included.
-f list_filename
Adds files and directories from a list to the archive.
list_filename is the full path to a file
that contains a list. The contents of the file are added to the file list
unless -F is specified.
The list_filename file must contain
one file per line.
If you specify a file system with -R root, the path to each file must be relative to the alternate root directory or an absolute path.
If filename is “-”, flarcreate reads standard input as the list of files. When you
use the value “-”, the archive size is not calculated.
-F
Uses only the files in -f list_filename to
create the archive. This option makes the -f list_filename the absolute list, rather than a list that is appended to the
normal file list.
Excludes files and directories from the archive. These files and directories
are specified at the command line. You can use multiple instances of this
option to exclude more than one file or directory.
exclude_dir/filename is the name of the directory
or file to be excluded.
-X list_filename
Excludes a list of files or directories from the archive.
that contains the list.
one file per line.
If list_filename is “-”, flarcreate reads standard input as the list of files. When you
-z list_filename
Excludes or includes a list of files or directories from the archive.
Each file or directory in the list is noted with a plus “+” or
minus “-”. A plus indicates an included file or directory and
the minus indicates an excluded file or directory.
one file per line.
-I
Override the integrity check. To prevent you from excluding important
system files from an archive, flarcreate runs an integrity
check. This check examines all files that are registered in a system package
database and stops archive creation if any of them are excluded. Use of this
option overrides this integrity check. Therefore, avoid the use of the -I option.
Options for Splitting and Merging Archives
-d dir
Retrieves the sections to copy from dir,
rather than from the current directory.
-u section
If you use this option, flar copies the
cookie, identification, archive, and section sections.
You can specify a single section name or a space-separated list of section
names.
If you do not use this option, flar copies the cookie, ldentification, and archive sections only.
-f archive
Extracts the archive section into a directory that is named archive, rather than placing it in a file with the name archive.
Used for splitting an archive.
-S section
Only copies the section that is named section from
the archive. This section is user defined. Used for splitting an archive.
Option Used To Copy Files (Archive)
-L pax
The cpio utility is the default copy method. If you
have large individual files, the -L pax option uses the pax utility to create an archive without limitations on individual
file sizes. Individual file sizes can be greater than 4 GB.
Options Used With User-Defined Sections
-u section
Includes section as a user-defined section.
To include more than one user-defined section, section must
be a space-separated list of section names.
-d dir
Retrieves the section file that is specified with -u from dir.
Options Used With Tape Archives
-t
Creates an archive on a tape device. The filename argument
is the name of the tape device.
-p posn
Use only with the -t option. Specifies the position
on the tape device for flarcreate to store the archive.
If you do not use this option, flarcreate places the archive
at the current position of the tape.
-b blocksize
Specifies the block size flarcreate uses when creating
the archive. If you do not specify a block size, flarcreate uses
the default block size of 64 KB.
Options for Archive Identification
These keywords and values appear in the archive identification section
of the archive.
-U key=val
Includes user-defined keywords and values in the archive identification
section.
-i date
Uses date as the value for the creation_date keyword. If you do not specify a date, flarcreate uses
the current system time and date.
-m master
Uses master as the name of the master system
on which you created the archive. master is the
value for the creation_master keyword. If you do not
specify master, flarcreate uses
the system name that is reported by uname -n.
-e descr
Uses descr for the value of the content_description keyword. You cannot use this option when you use the -E option.
-E descr_file
Retrieves the value for the content_description keyword
from the descr_file file. You cannot use this
option when you use the -e option.
-a author
Uses author as the author name in the archive
identification section. author is the value for
the content_author keyword. If you do not specify an author, flarcreate does not include the content_author keyword
in the archive identification section.
-T type
Uses type as the value for the content_type keyword. type is user defined. If you
do not specify a type, flarcreate does not include the content_type keyword.
