Solaris 10 10/08 Release Notes
Solaris Volume Manager
The following Solaris Volume Manager bugs apply to the Solaris 10 release.
Solaris Volume Manager metattach Command Might Fail
If you have a Solaris Volume Manager mirrored root (/) file system in which the file system does not start on cylinder 0, all submirrors you attach must also not start on cylinder 0.
If you attempt to attach a submirror starting on cylinder 0 to a mirror in which the original submirror does not start on cylinder 0, the following error message is displayed:
can't attach labeled submirror to an unlabeled mirror
Workaround: Choose one of the following workarounds:
Note –
By default, the JumpStart installation process starts swap at cylinder 0 and the root (/) file system somewhere else on the disk. Common system administration practice is to start slice 0 at cylinder 0. Mirroring a default JumpStart installation with root on slice 0, but not cylinder 0, to a typical secondary disk with slice 0 that starts at cylinder 0, can cause problems. This mirroring results in an error message when you attempt to attach the second submirror. For more information about the default behavior of Solaris installation programs, see the Solaris 10 Installation Guides.
Solaris Volume Manager metassist Command Fails in Non-English Locales (5067097)
In non-English locales, the Solaris Volume Manager metassist command might fail to create volumes. For example, if LANG is set to ja (Japanese), the following error message is displayed:
xmlEncodeEntitiesReentrant : input not UTF-8
Syntax of value for attribute read on mirror is not valid
Value "XXXXXX"(unknown word) for attribute read on mirror
is not among the enumerated set
Syntax of value for attribute write on mirror is not valid
Value "XXXXXX"(Parallel in Japanse) for attribute write on mirror
metassist: XXXXXX(invalid in Japanese) volume-config
Workaround: As superuser, set the LANG variable to LANG=C.
For the Bourne, Korn, and Bash shells, use the following command:
# LANG=C; export LANG
For the C shell, use the following command:
# setenv LANG C
Volume Creation Fails in Systems With Unformatted Disks (5064066)
Creating Solaris Volume Manager volume configurations with the metassist command might fail if an unformatted disk is in the system. The following error message is displayed:
metassist: failed to repartition disk
Workaround: Manually format any unformatted disks before you issue the metassist command.
Hot Spares Do Not Work Correctly When Solaris Volume Manager RAID-1 (Mirror) or RAID-5 Volumes Are Created in Disk Sets Built on Soft Partitions (4981358)
If you create a Solaris Volume Manager RAID-1 (mirror) or RAID-5 volume in a disk set that is built on top of a soft partition, hot spare devices do not work correctly.
Problems that you might encounter include, but are not limited to, the following:
Solaris Volume Manager metadevadm Command Fails if Logical Device Name No Longer Exists (4645721)
You cannot replace a failed drive with a drive that has been configured with the Solaris Volume Manager software. The replacement drive must be new to Solaris Volume Manager software. If you physically move a disk from one slot to another slot on a Sun StorEdge A5x00, the metadevadm command fails. This failure occurs when the logical device name for the slice no longer exists. However, the device ID for the disk remains present in the metadevice replica. The following message is displayed:
Unnamed device detected. Please run 'devfsadm && metadevadm -r to resolve.
Note –
You can access the disk at the new location during this time. However, you might need to use the old logical device name to access the slice.
Workaround: Physically move the drive back to its original slot.
Solaris Volume Manager metarecover Command Fails to Update metadb Namespace (4645776)
If you remove and replace a physical disk from the system, and then use the metarecover -p -d command to write the appropriate soft partition specific information to the disk, an open failure results. The command does not update the metadevice database namespace to reflect the change in disk device identification. The condition causes an open failure for each such soft partition that is built on top of the disk. The following message is displayed:
Open Error
Workaround: Create a soft partition on the new disk instead of using the metarecover command to recover the soft partition.
Note –
If the soft partition is part of a mirror or RAID 5, use the metareplace command without the -e option to replace the old soft partition with the new soft partition.
# metareplace dx mirror or RAID 5
old_soft_partition new_soft_partition
