Supposons que la version x86 de SUNWstuf est déjà installée sur le serveur dans /opt/SUNWstuf. Lorsque l'administrateur utilise la commande pkgadd pour installer la version SPARC, le script request doit détecter l'existence de la version x86 et interagir avec l'administrateur pour l'installation.
Le répertoire de base peut être parcouru sans l'interaction de l'administrateur dans un script checkinstall ; toutefois, lorsque des opérations arbitraires de ce type se produisent trop souvent, les administrateurs n'ont plus confiance dans la procédure.
Les scripts request et checkinstall d'un package gérant cette situation peuvent ressembler aux suivants :
# request script
for SUNWstuf to walk the BASEDIR parameter.
PATH=/usr/sadm/bin:${PATH} # use admin utilities
GENMSG="The base directory $LOCAL_BASE already contains a \
different architecture or version of $PKG."
OLDMSG="If the option \"-a none\" was used, press the \
key and enter an unused base directory when it is requested."
OLDPROMPT="Do you want to overwrite this version? "
OLDHELP="\"y\" will replace the installed package, \"n\" will \
stop the installation."
SUSPEND="Suspending installation at user request using error \
code 1."
MSG="This package could be installed at the unused base directory $WRKNG_BASE."
PROMPT="Do you want to use to the proposed base directory? "
HELP="A response of \"y\" will install to the proposed directory and continue,
\"n\" will request a different directory. If the option \"-a none\" was used,
press the key and enter an unused base directory when it is requested."
DIRPROMPT="Select a preferred base directory ($WRKNG_BASE) "
DIRHELP="The package $PKG will be installed at the location entered."
NUBD_MSG="The base directory has changed. Be sure to update \
any applicable search paths with the actual location of the \
binaries which are at $WRKNG_BASE/EZstuf and $WRKNG_BASE/HRDstuf."
OldSolaris=""
Changed=""
Suffix="0"
# Determine if this product is actually installed in the working
# base directory.
Product_is_present () {
if [ -d $WRKNG_BASE/EZstuf -o -d $WRKNG_BASE/HRDstuf ]; then
return 1
else
return 0
fi
if [ ${BASEDIR} ]; then
# This may be an old version of Solaris. In the latest Solaris
# CLIENT_BASEDIR won't be defined yet. In older version it is.
if [ ${CLIENT_BASEDIR} ]; then
LOCAL_BASE=$BASEDIR
OldSolaris="true"
else # The base directory hasn't been processed yet
LOCAL_BASE=${PKG_INSTALL_ROOT}$BASEDIR
fi
WRKNG_BASE=$LOCAL_BASE
# See if the base directory is already in place and walk it if
# possible
while [ -d ${WRKNG_BASE} -a Product_is_present ]; do
# There is a conflict
# Is this an update of the same arch & version?
if [ ${UPDATE} ]; then
exit 0 # It's out of our hands.
else
# So this is a different architecture or
# version than what is already there.
# Walk the base directory
Suffix=`expr $Suffix + 1`
WRKNG_BASE=$LOCAL_BASE.$Suffix
Changed="true"
fi
done
# So now we can propose a base directory that isn't claimed by
# any of our other versions.
if [ $Changed ]; then
puttext "$GENMSG"
if [ $OldSolaris ]; then
puttext "$OLDMSG"
result=`ckyorn -Q -d "a" -h "$OLDHELP" -p "$OLDPROMPT"`
if [ $result="n" ]; then
puttext "$SUSPEND"
exit 1 # suspend installation
else
exit 0
fi
else # The latest functionality is available
puttext "$MSG"
result=`ckyorn -Q -d "a" -h "$HELP" -p "$PROMPT"`
if [ $? -eq 3]; then
echo quitinstall >> $1
exit 0
fi
WRKNG_BASE=`ckpath -ayw -d "$WRKNG_BASE" \
-h "$DIRHELP" -p "$DIRPROMPT"`
else if [ $result="a" ]
exit 0
fi
fi
echo "BASEDIR=$WRKNG_BASE" >> $1
puttext "$NUBD_MSG"
fi
fi
exit 0
# checkinstall script for SUNWstuf to politely suspend grep quitinstall $1 if [ $? -eq 0 ]; then exit 3 # politely suspend installation fi exit 0 |
Cette approche ne serait pas très efficace si le répertoire de base était simplement /opt. Ce package doit faire référence à BASEDIR de manière plus précise car le parcours de /opt pourrait s'avérer difficile. En fait, selon le schéma de montage, l'opération peut même s'avérer impossible. L'exemple parcourt le répertoire de base en créant un nouveau répertoire sous /opt, ce qui ne crée aucun problème.
Cet exemple utilise un script request et un script checkinstall, bien que les versions antérieures à Solaris 2.5 ne puissent pas exécuter de script checkinstall. Le script checkinstall de cet exemple est utilisé afin de suspendre poliment l'installation en réponse à un message privé sous la forme d'une chaîne quitinstall ». Si ce script s'exécute sous Solaris 2.3, le script checkinstall est ignoré et le script request suspend l'installation en affichant un message d'erreur.
N'oubliez pas que pour les versions antérieures à Solaris 2.5 et versions compatibles, le paramètre BASEDIR est un paramètre en lecture seule qui ne peut pas être modifié par le script request. Pour cette raison, lorsqu'une ancienne version du système d'exploitation SunOS est détectée (en recherchant une variable d'environnement CLIENT_BASEDIR conditionnée), le script request n'a que deux possibilités : poursuivre ou abandonner l'opération.
