# request script for SUNWstuf to walk a parametric path PATH=/usr/sadm/bin:${PATH} # use admin utilities MSG="The target directory $LOCAL_BASE already contains \ different architecture or version of $PKG. This package \ could be installed at the unused target directory $WRKNG_BASE." PROMPT="Do you want to use to the proposed directory? " HELP="A response of \"y\" will install to the proposed directory \ and continue, \"n\" will request a different directory. If \ the option \"-a none\" was used, press the <RETURN> key and \ enter an unused base directory when it is requested." DIRPROMPT="Select a relative target directory under $BASEDIR/" DIRHELP="The package $PKG will be installed at the location entered." SUSPEND="Suspending installation at user request using error \ code 1." NUBD_MSG="The location of this package is not the default. Be \ sure to update any applicable search paths with the actual \ location of the binaries which are at $WRKNG_BASE/EZstuf \ and $WRKNG_BASE/HRDstuf." Changed="" Suffix="0" # # Determine if this product is actually installed in the working # base directory. # Product_is_present () { if [ -d $WRKNG_BASE/EZstuf -o -d $WRKNG_BASE/HRDstuf ]; then return 1 else return 0 fi } if [ ${BASEDIR} ]; then # This may be an old version of Solaris. In the latest Solaris # CLIENT_BASEDIR won't be defined yet. In older versions it is. if [ ${CLIENT_BASEDIR} ]; then LOCAL_BASE=$BASEDIR/$SUBBASE else # The base directory hasn't been processed yet LOCAL_BASE=${PKG_INSTALL_ROOT}$BASEDIR/$SUBBASE fi WRKNG_BASE=$LOCAL_BASE # See if the base directory is already in place and walk it if # possible while [ -d ${WRKNG_BASE} -a Product_is_present ]; do # There is a conflict # Is this an update of the same arch & version? if [ ${UPDATE} ]; then exit 0 # It's out of our hands. else # So this is a different architecture or # version than what is already there. # Walk the base directory Suffix=`expr $Suffix + 1` WRKNG_BASE=$LOCAL_BASE.$Suffix Changed="true" fi done # So now we can propose a base directory that isn't claimed by # any of our other versions. if [ $Changed ]; then puttext "$MSG" result=`ckyorn -Q -d "a" -h "$HELP" -p "$PROMPT"` if [ $? -eq 3 ]; then puttext "$SUSPEND" exit 1 fi if [ $result="n" ]; then WRKNG_BASE=`ckpath -lyw -d "$WRKNG_BASE" -h "$DIRHELP" \ -p "$DIRPROMPT"` elif [ $result="a" ]; then exit 0 else exit 1 fi echo SUBBASE=$SUBBASE.$Suffix >> $1 puttext "$NUBD_MSG" fi fi exit 0 |
