应用程序包开发者指南
preinstall 脚本
preinstall 脚本可初始化 prototype 文件、信息文件和安装脚本,以便构建回退软件包。此脚本非常简单,并且此示例中的其余脚本只允许回退软件包描述常规文件。
如果您要在回退软件包中恢复符号链接、硬链接、设备和命名管道,可以修改 preinstall 脚本,以便使用 pkgproto 命令将交付的 pkgmap 文件与安装的文件进行比较,然后为要在回退软件包中更改的每个非文件创建一个 prototype 文件条目。应该使用的方法类似于类操作脚本中的方法。
脚本 patch_checkinstall 和 patch_postinstall 会从 preinstall 脚本插入到软件包源树中。这两个脚本撤消了修补程序执行的操作。
# This script initializes the backout data for a patch package
# directory format options.
#       @(#)preinstall 1.5 96/05/10 SMI
# Copyright (c) 1995 by Sun Microsystems, Inc.
# All rights reserved
PATH=/usr/sadm/bin:$PATH
recovery="no"
if [ "$PKG_INSTALL_ROOT" = "/" ]; then
        PKG_INSTALL_ROOT=""
fi
# Check to see if this is a patch installation retry.
if [ "$INTERRUPTION" = "yes" ]; then
    if [ -d "$PKG_INSTALL_ROOT/var/tmp/$Patch_label.$PKGINST" ] || [ -d \
"$PATCH_BUILD_DIR/$Patch_label.$PKGINST" ]; then
        recovery="yes"
    fi
fi
if [ -n "$PATCH_BUILD_DIR" -a -d "$PATCH_BUILD_DIR" ]; then
        BUILD_DIR="$PATCH_BUILD_DIR/$Patch_label.$PKGINST"
else
        BUILD_DIR="$PKG_INSTALL_ROOT/var/tmp/$Patch_label.$PKGINST"
fi
FILE_DIR=$BUILD_DIR/files
RELOC_DIR=$BUILD_DIR/files/reloc
ROOT_DIR=$BUILD_DIR/files/root
PROTO_FILE=$BUILD_DIR/prototype
PKGINFO_FILE=$BUILD_DIR/pkginfo
THIS_DIR=`dirname $0`
if [ "$PATCH_PROGRESSIVE" = "true" ]; then
        # If this is being used in an old-style patch, insert
        # the old-style script commands here.
        #XXXOld_CommandsXXX#
        exit 0
fi
# Unless specifically denied, initialize the backout patch data by
# creating the build directory and copying over the original pkginfo
# which pkgadd saved in case it had to be restored.
if [ "$PATCH_NO_UNDO" != "true" ] && [ "$recovery" = "no" ]; then
        if [ -d $BUILD_DIR ]; then
                rm -r $BUILD_DIR
        fi
        # If this is a retry of the same patch then recovery is set to
        # yes. Which means there is a build directory already in
        # place with the correct backout data.
        if [ "$recovery" = "no" ]; then
                mkdir $BUILD_DIR
                mkdir -p $RELOC_DIR
                mkdir $ROOT_DIR
        fi
        # Here we initialize the backout pkginfo file by first
        # copying over the old pkginfo file and themn adding the
        # ACTIVE_PATCH parameter so the backout will know what patch
        # it's backing out.
        # NOTE : Within the installation, pkgparam returns the
        # original data.
        pkgparam -v $PKGINST | nawk '
                $1 ~ /PATCHLIST/        { next; }
                $1 ~ /PATCH_OBSOLETES/  { next; }
                $1 ~ /ACTIVE_OBSOLETES/ { next; }
                $1 ~ /Obsoletes_label/  { next; }
                $1 ~ /ACTIVE_PATCH/     { next; }
                $1 ~ /Patch_label/      { next; }
                $1 ~ /UPDATE/   { next; }
                $1 ~ /SCRIPTS_DIR/      { next; }
                $1 ~ /PATCH_NO_UNDO/    { next; }
                $1 ~ /INSTDATE/ { next; }
                $1 ~ /PKGINST/  { next; }
                $1 ~ /OAMBASE/  { next; }
                $1 ~ /PATH/     { next; }
                { print; } ' > $PKGINFO_FILE
        echo "ACTIVE_PATCH=$Patch_label" >> $PKGINFO_FILE
        echo "ACTIVE_OBSOLETES=$ACTIVE_OBSOLETES" >> $PKGINFO_FILE
        # And now initialize the backout prototype file with the
        # pkginfo file just formulated.
        echo "i pkginfo" > $PROTO_FILE
        # Copy over the backout scripts including the undo class
        # action scripts
        for script in $SCRIPTS_DIR/*; do
                srcscript=`basename $script`
                targscript=`echo $srcscript | nawk '
                        { script=$0; }
                        /u\./ {
                                sub("u.", "i.", script);
                                print script;
                                next;
                        /patch_/ {
                                sub("patch_", "", script);
                                print script;
                                next;
                        { print "dont_use" } '`
                if [ "$targscript" = "dont_use" ]; then
                        continue
                fi
                echo "i $targscript=$FILE_DIR/$targscript" >> $PROTO_FILE
                cp $SCRIPTS_DIR/$srcscript $FILE_DIR/$targscript
        done
        # Now add entries to the prototype file that won't be passed to
        # class action scripts. If the entry is brand new, add it to the
        # deletes file for the backout package.
        Our_Pkgmap=`dirname $SCRIPTS_DIR`/pkgmap
        BO_Deletes=$FILE_DIR/deletes
        nawk -v basedir=${BASEDIR:-/} '
                BEGIN { count=0; }
                        token = $2;
                        ftype = $1;
                $1 ~ /[#\!:]/ { next; }
                $1 ~ /[0123456789]/ {
                        if ( NF >= 3) {
                                token = $3;
                                ftype = $2;
                        } else {
                                next;
                { if (ftype == "i" || ftype == "e" || ftype == "f" || ftype == \
"v" || ftype == "d") { next; } }
                        equals=match($4, "=")-1;
                        if ( equals == -1 ) { print $3, $4; }
                        else { print $3, substr($4, 0, equals); }
                ' < $Our_Pkgmap | while read class path; do
                        # NOTE: If pkgproto is passed a file that is
                        # actually a hard link to another file, it
                        # will return ftype "f" because the first link
                        # in the list (consisting of only one file) is
                        # viewed by pkgproto as the source and always
                        # gets ftype "f".
                        # If this isn't replacing something, then it
                        # just goes to the deletes list.
                        if valpath -l $path; then
                                Chk_Path="$BASEDIR/$path"
                                Build_Path="$RELOC_DIR/$path"
                                Proto_From="$BASEDIR"
                        else    # It's an absolute path
                                Chk_Path="$PKG_INSTALL_ROOT$path"
                                Build_Path="$ROOT_DIR$path"
                                Proto_From="$PKG_INSTALL_ROOT"
                        fi
                        # Hard links have to be restored as regular files.
                        # Unlike the others in this group, an actual
                        # object will be required for the pkgmk.
                        if [ -f "$Chk_Path" ]; then
                                mkdir -p `dirname $Build_Path`
                                cp $Chk_Path $Build_Path
                                cd $Proto_From
                                pkgproto -c $class "$Build_Path=$path" 1>> \
$PROTO_FILE 2> /dev/null
                                cd $THIS_DIR
                        elif [ -h "$Chk_Path" -o \
                             -c "$Chk_Path" -o \
                             -b "$Chk_Path" -o \
                             -p "$Chk_Path" ]; then
                                pkgproto -c $class "$Chk_Path=$path" 1>> \
                        else
                                echo $path >> $BO_Deletes
                        fi
                done
fi
# If additional operations are required for this package, place
# those package-specific commands here.
#XXXSpecial_CommandsXXX#
exit 0
