假定 SUNWstuf 的 x86 版本已经安装在服务器上的 /opt/SUNWstuf 中。当管理员使用 pkgadd 命令安装 SPARC 版本时,request 脚本需要检测是否存在 x86 版本并且与管理员就安装问题进行交互。
可在 checkinstall 脚本中遍历基目录而无需管理员交互,但是,如果此类任意操作的发生过于频繁,管理员会在此过程中失去信心。
软件包的用于处理此情形的 request 脚本和 checkinstall 脚本可能如下所示。
# request script
for SUNWstuf to walk the BASEDIR parameter.
PATH=/usr/sadm/bin:${PATH} # use admin utilities
GENMSG="The base directory $LOCAL_BASE already contains a \
different architecture or version of $PKG."
OLDMSG="If the option \"-a none\" was used, press the \
key and enter an unused base directory when it is requested."
OLDPROMPT="Do you want to overwrite this version? "
OLDHELP="\"y\" will replace the installed package, \"n\" will \
stop the installation."
SUSPEND="Suspending installation at user request using error \
code 1."
MSG="This package could be installed at the unused base directory $WRKNG_BASE."
PROMPT="Do you want to use to the proposed base directory? "
HELP="A response of \"y\" will install to the proposed directory and continue,
\"n\" will request a different directory. If the option \"-a none\" was used,
press the key and enter an unused base directory when it is requested."
DIRPROMPT="Select a preferred base directory ($WRKNG_BASE) "
DIRHELP="The package $PKG will be installed at the location entered."
NUBD_MSG="The base directory has changed. Be sure to update \
any applicable search paths with the actual location of the \
binaries which are at $WRKNG_BASE/EZstuf and $WRKNG_BASE/HRDstuf."
OldSolaris=""
Changed=""
Suffix="0"
# Determine if this product is actually installed in the working
# base directory.
Product_is_present () {
if [ -d $WRKNG_BASE/EZstuf -o -d $WRKNG_BASE/HRDstuf ]; then
return 1
else
return 0
fi
if [ ${BASEDIR} ]; then
# This may be an old version of Solaris. In the latest Solaris
# CLIENT_BASEDIR won't be defined yet. In older version it is.
if [ ${CLIENT_BASEDIR} ]; then
LOCAL_BASE=$BASEDIR
OldSolaris="true"
else # The base directory hasn't been processed yet
LOCAL_BASE=${PKG_INSTALL_ROOT}$BASEDIR
fi
WRKNG_BASE=$LOCAL_BASE
# See if the base directory is already in place and walk it if
# possible
while [ -d ${WRKNG_BASE} -a Product_is_present ]; do
# There is a conflict
# Is this an update of the same arch & version?
if [ ${UPDATE} ]; then
exit 0 # It's out of our hands.
else
# So this is a different architecture or
# version than what is already there.
# Walk the base directory
Suffix=`expr $Suffix + 1`
WRKNG_BASE=$LOCAL_BASE.$Suffix
Changed="true"
fi
done
# So now we can propose a base directory that isn't claimed by
# any of our other versions.
if [ $Changed ]; then
puttext "$GENMSG"
if [ $OldSolaris ]; then
puttext "$OLDMSG"
result=`ckyorn -Q -d "a" -h "$OLDHELP" -p "$OLDPROMPT"`
if [ $result="n" ]; then
puttext "$SUSPEND"
exit 1 # suspend installation
else
exit 0
fi
else # The latest functionality is available
puttext "$MSG"
result=`ckyorn -Q -d "a" -h "$HELP" -p "$PROMPT"`
if [ $? -eq 3]; then
echo quitinstall >> $1
exit 0
fi
WRKNG_BASE=`ckpath -ayw -d "$WRKNG_BASE" \
-h "$DIRHELP" -p "$DIRPROMPT"`
else if [ $result="a" ]
exit 0
fi
fi
echo "BASEDIR=$WRKNG_BASE" >> $1
puttext "$NUBD_MSG"
fi
fi
exit 0
# checkinstall script for SUNWstuf to politely suspend grep quitinstall $1 if [ $? -eq 0 ]; then exit 3 # politely suspend installation fi exit 0 |
如果基目录仅仅是 /opt,则此方法不会非常有效。因为 /opt 难以遍历,所以此软件包必须更加准确地调用 BASEDIR。实际上,根据挂载方案的不同,可能无法实现这一点。此示例通过在 /opt 下创建一个新目录来遍历基目录,这种方法不会导致任何问题。
此示例使用 request 脚本和 checkinstall 脚本,即使 Solaris 2.5 发行版以前的版本无法运行 checkinstall 脚本。此示例中的 checkinstall 脚本用于正常停止安装,以响应一个采用 quitinstall 字符串形式的专用消息。如果此脚本在 Solaris 2.3 发行版中执行,checkinstall 脚本将被忽略,而 request 脚本将停止安装并显示错误消息。
请记住,在 Solaris 2.5 和兼容发行版之前,BASEDIR 参数是一个只读参数,不能通过 request 脚本更改。因此,如果检测到 SunOS 操作系统的早期版本(通过测试 CLIENT_BASEDIR 条件环境变量),request 脚本只有两种选择-继续或退出。
