借助表 8–2,您可根据安装方案快速确定可以使用的关键字。除非在关键字描述中另有说明,否则该关键字只能用于初始安装选项。此外,除非注明了关键字可在 ZFS 根池配置文件中使用,否则,这些关键字用于 UFS 文件系统。
表 8–2 配置文件关键字概述| 安装方案 | ||||||
| 配置文件关键字 | 独立系统(非联网的) | 独立系统(联网的)或服务器 | OS 服务器 | 升级 | 升级时重新分配磁盘空间 | 可用于 ZFS 根池 |
| archive_location(安装 Solaris Flash 归档文件) | X | X | ||||
| backup_media | X | |||||
| boot_device(UFS 和 ZFS) | X | X | X | X | ||
| bootenv(UFS 和 ZFS) | X | X | X | X | ||
| client_arch | X | |||||
| client_root | X | |||||
| client_swap | X | |||||
| cluster(添加软件组)(UFS 和 ZFS) | X | X | X | X | ||
| cluster(添加或删除簇)(UFS 和 ZFS) | X | X | X | X | X | X |
| dontuse(UFS 和 ZFS) | X | X | X | X | ||
| fdisk(仅 x86)(UFS 和 ZFS) | X | X | X | X | ||
| filesys(安装远程文件系统)(UFS 和 ZFS) | X | X | X | |||
| filesys(创建本地文件系统) | X | X | X | |||
| filesys(创建镜像的文件系统) | X | X | X |
| forced_deployment (安装 Solaris Flash 差别归档文件) | X | X |
| geo(UFS 和 ZFS) | X | X | X | X | X | X |
| install_type(UFS 和 ZFS) | X | X | X | X | X | X |
| layout_constraint | X | |||||
| local_customization(安装 Solaris Flash 归档文件) | X | X |
| locale(UFS 和 ZFS) | X | X | X | X | X | X |
| metadb(创建状态数据库副本) | X | X | X |
| no_master_check(安装 Solaris Flash 差别归档文件) | X | X |
| no_content_check(安装 Solaris Flash 差别归档文件) | X | X |
| num_clients | X | |||||
| package(UFS 和 ZFS) | X | X | X | X | X | X |
| partitioning | X | X | X |
| patch(修补程序) | X | X | X | X | X | |
| pool(仅 ZFS 根池) | X | X | X | X | ||
| root_device(UFS 和 ZFS) | X | X | X | X | X | X |
| system_type | X | X | X |
| usedisk(UFS 和 ZFS) | X | X | X | X | ||
