Requirement Type |
Size |
Note – Some optional installation features are enabled only when sufficient memory is present. For example, if your system has insufficient memory and you install from a DVD, you install through the Solaris installation program 's text installer, not through the GUI. For more information about these memory requirements, see Table 4–2. |
Swap area |
Note – You might need to customize the swap space. Swap space is based on the size of the system's hard disk. |
Processor requirements |
You can choose to install the software with a GUI or with or without a windowing environment. If there is sufficient memory, the GUI is displayed by default. Other environments are displayed by default if memory is insufficient for the GUI. You can override defaults with the nowin or text boot options. But, you are limited by the amount of memory in your system or by installing remotely. Also if the Solaris installation program does not detect a video adapter, it automatically displays in a console-based environment. Table 4–2 describes these environments and lists minimal memory requirements for displaying them.
Table 4–2 Memory Requirements for Display Options
