Before running Solaris Live Upgrade, you must install the latest Solaris Live Upgrade packages from installation media and install the patches listed in the SunSolveSM info doc 206844. You need to install the Solaris Live Upgrade packages on your current OS and remove old packages. The release of the Solaris Live Upgrade packages must match the release of the OS you are upgrading to. For example, if your current OS is the Solaris 9 release and you want to upgrade to the Solaris 10 5/09 release, you need to install the Solaris Live Upgrade packages from the Solaris 10 5/09 release. The patches listed in Sunsolve info doc 206844 also need to be installed. The latest packages and patches ensure that you have all the latest bug fixes and new features in the release. Ensure that you install all the patches that are relevant to your system before proceeding to create a new boot environment.
The Sunsolve info doc 206844 describes how to remove old packages and install new packages, as well as lists the required patches. The procedures below provided more description for the procedures described in info doc 206844.
You can install the packages by using the liveupgrade20 command that is on the installation DVD or CD or use the pkgadd command. The liveupgrade20 command requires Java software. If your system does not have Java software installed, then you need to use the pkgadd command to install the packages. See the SunSolve info doc for more information.
Become superuser or assume an equivalent role.
Roles contain authorizations and privileged commands. For more information about roles, see Configuring RBAC (Task Map) in System Administration Guide: Security Services.
Remove existing Solaris Live Upgrade packages.
The three Solaris Live Upgrade packages, SUNWluu, SUNWlur, and SUNWlucfg, comprise the software needed to upgrade or patch by using Solaris Live Upgrade. These packages include existing software, new features, and bug fixes. If you do not remove the existing packages and install the new packages on your system before using Solaris Live Upgrade, upgrading or patching to the target release fails. The SUMWlucfg package is new starting with the Solaris 10 8/07 release. If you are using Solaris Live Upgrade packages from a release previous to Solaris 10 8/07, you do not need to remove this package.
# pkgrm SUNWlucfg SUNWluu SUNWlur |
Install the packages in the following order.
# pkgadd -d path_to_packages SUNWlucfg SUNWlur SUNWluu |
Specifies the absolute path to the software packages.
Verify that the package has been installed successfully.
# pkgchk -v SUNWlucfg SUNWlur SUNWluu |
You can install the packages by using the liveupgrade20 command that is on the installation DVD or CD. The liveupgrade20 command requires Java software. If your system does not have Java software installed, then you need to use the pkgadd command to install the packages. See the SunSolve info doc for more information.
This procedure assumes that the system is running Volume Manager. For detailed information about managing removable media with the Volume Manager, refer to System Administration Guide: Devices and File Systems.
Insert the Solaris Operating System DVD or Solaris Software - 2 CD.
Run the installer for the media you are using.
If you are using the Solaris Operating System DVD, change directories to the installer and run the installer.
# cd /cdrom/cdrom0/Solaris_10/Tools/Installers # ./liveupgrade20 |
The Solaris installation program GUI is displayed. If you are using a script, you can prevent the GUI from displaying by using the -noconsole and -nodisplay options.
If you are using the Solaris Software - 2 CD, run the installer.
% ./installer |
From the Select Type of Install panel, click Custom.
On the Locale Selection panel, click the language to be installed.
Choose the software to install.
For DVD, on the Component Selection panel, click Next to install the packages.
For CD, on the Product Selection panel, click Default Install for Solaris Live Upgrade and click on the other software choices to deselect them.
Follow the directions on the Solaris installation program panels to install the software.
You are ready to install the required patches.
Description |
For More Information |
Correct operation of Solaris Live Upgrade requires that a limited set of patch revisions be installed for a particular OS version. Before installing or running Solaris Live Upgrade, you are required to install these patches. x86 only – If this set of patches is not installed, Solaris Live Upgrade fails and you might see the following error message. If you don't see the following error message, necessary patches still might not be installed. Always verify that all patches listed on the SunSolve info doc have been installed before attempting to install Solaris Live Upgrade.
The patches listed in info doc 206844 (formerly 72099) are subject to change at any time. These patches potentially fix defects in Solaris Live Upgrade, as well as fix defects in components that Solaris Live Upgrade depends on. If you experience any difficulties with Solaris Live Upgrade, please check and make sure that you have the latest Solaris Live Upgrade patches installed. |
Ensure you have the most recently updated patch list by consulting http://sunsolve.sun.com. Search for the info doc 206844 (formerly 72099) on the SunSolve web site. |
If you are running the Solaris 8 or Solaris 9 OS, you might not be able to run the Solaris Live Upgrade installer. These releases do not contain the set of patches needed to run the Java 2 runtime environment. You must have the recommended patch cluster for the Java 2 runtime environment that is recommended to run the Solaris Live Upgrade installer and install the packages. |
To install the Solaris Live Upgrade packages, use the pkgadd command. Or install, for the Java 2 runtime environment, the recommended patch cluster. The patch cluster is available at http://sunsolve.sun.com. |
If you are storing the patches on a local disk, create a directory such as /var/tmp/lupatches.
From the SunSolve web site, obtain the list of patches.
Change to the patch directory as in this example.
# cd /var/tmp/lupatches |
Install the patches with the patchadd command.
# patchadd path_to_patches patch-id patch-id |
patch-id is the patch number or numbers. Separate multiple patch names with a space.
The patches need to be applied in the order specified in infodoc 206844.
Reboot the system if necessary. Certain patches require a reboot to be effective.
x86 only: Rebooting the system is required or Solaris Live Upgrade fails.
# init 6 |
You now have the packages and patches necessary for a successful creation of a new boot environment.
