Solaris 10 5/09 Installation Guide: Custom JumpStart and Advanced Installations
Profile Keywords Quick Reference
Table 8–2 provides a quick way to determine which keywords you can use, based on your installation scenario. Unless otherwise noted in the keyword descriptions, the keyword can only be used with the initial installation option. Also, these keywords are for a UFS file system unless noted that the keyword can be used in a ZFS root pool profile.
Table 8–2 Profile Keywords Overview
Installation Scenarios
Profile Keyword
Standalone System (Nonnetworked)
Standalone System (Networked) or Server
OS Server
Upgrade
Upgrade With Disk Space Reallocation
Can be Used for a ZFS Root Pool
archive_location (installing Solaris Flash archives)
X
X
backup_media
X
boot_device (UFS and ZFS)
X
X
X
X
bootenv (UFS and ZFS)
X
X
X
X
client_arch
X
client_root
X
client_swap
X
cluster (adding software groups) (UFS and ZFS)
X
X
X
X
cluster (adding or deleting clusters) (UFS and ZFS)
X
X
X
X
X
X
dontuse (UFS and ZFS)
X
X
X
X
fdisk (x86 only) (UFS and ZFS)
X
X
X
X
filesys (mounting remote file systems) (UFS and ZFS)
X
X
X
filesys (creating local file systems)
X
X
X
filesys (creating mirrored file systems)
X
X
X
forced_deployment (installing Solaris Flash differential archives)
X
X
geo (UFS and ZFS)
X
X
X
X
X
X
install_type (UFS and ZFS)
X
X
X
X
X
X
layout_constraint
X
local_customization (installing Solaris Flash archives)
X
X
locale (UFS and ZFS)
X
X
X
X
X
X
metadb (creating state database replicas)
X
X
X
no_master_check (installing Solaris Flash differential archives)
X
X
no_content_check (installing Solaris Flash differential archives)
X
X
num_clients
X
package (UFS and ZFS)
X
X
X
X
X
X
partitioning
X
X
X
patch
X
X
X
X
X
pool (ZFS root pools only)
X
X
X
X
root_device (UFS and ZFS)
X
X
X
X
X
X
system_type
X
X
X
usedisk (UFS and ZFS)
X
X
X
X
