Solaris 10 5/09 Installation Guide: Solaris Flash Archives (Creation and Installation)
Chapter 2 Solaris Flash (Planning)
This chapter provides information necessary for planning a Solaris Flash installation in your environment.
Planning Your Solaris Flash Installation
Before you create and install a Solaris Flash archive, you must make some decisions about how you want to install the Solaris OS on your systems. The first time that you install a system, you install with a full archive that is an initial installation. After a system has been installed with an archive, the system can be updated with a differential archive. The differential archive installs only the differences between two archives.
Review the following limitations before creating and installing a Solaris Flash archive.
Table 2–1 Limitations When Creating and Installing a Solaris Flash Archive
Limitation
Description
When installing the Solaris OS with a Solaris Flash archive, the archive and the installation media must contain identical operating system versions.
For example, if the archive is a Solaris 10 operating system and you are using DVD media, then you must use Solaris 10 DVD media to install the archive. If the operating systems versions do not match, the installation on the target system fails.
A Solaris Flash archive cannot be properly created when a non-global zone is installed.
The Solaris Flash feature is not compatible with the Solaris Zones partitioning technology. If you create a Solaris Flash archive, the resulting archive is not installed properly when the archive is deployed under these conditions:
  • The archive is created in a non-global zone
  • The archive is created in a global zone that has non-global zones installed
Starting with the Solaris 10 10/08 release, if you are installing a Solaris Flash archive from a release before the Solaris 10 10/08 release, the archive fails to install.
If you need to install a Solaris Flash archive from a previous release, boot from the previous release and install the archive.
A Solaris Flash archive can only be created and installed from a UFS file system.
You cannot create a Solaris Flash archive from a ZFS root pool. Also, you cannot install a Solaris Flash archive on a ZFS root pool.
Designing an Initial Installation of the Master System
The first task in the Solaris Flash installation process is to install a system, the master system, with the configuration that you want each of the clone systems to have. You can use any of the Solaris installation methods to install an archive on the master system. The installation can be a subset or a complete installation of the Solaris OS. After you complete the installation, you can add or remove software or modify any configuration files. Some limitations to installing the master system are the following:
Note –
If you already have installed clone systems and want to update these systems with a new configuration, see Planning to Create the Solaris Flash Differential Archive for an Update.
ProcedureInstalling a Sun4U Flash Archive on a Sun4V Machine
Before You Begin
Note the following limitations to this procedure:
  1. Create a Solaris Flash archive on a Sun4U machine, so that the archive can be installed on a Sun4V machine. Use one of the following two options to add Sun4V as a supported architecture for the archive.
    Note –
    You must start with a Sun4U machine that has been installed with the Entire Plus OEM Software Group, so that all the driver packages are in the image, even if these packages are not in use. For further information about this requirement, see SPARC: Supporting Peripheral Devices Not Found on the Master System.
    • Add the following information to the /var/sadm/system/admin/.platform file. Then, create the Solaris Flash archive.
      PLATFORM_GROUP=sun4v
      Note –
      You can verify that the Sun4V platform group is supported by using the following command:
      # flar -i <path_to_hybrid>.flar | grep content_architectures
      This command should display the following results:
      content_architectures=sun4u,sun4v
    • Create the Solaris Flash archive, using the -U option to add Sun4V as a supported architecture for the archive. See the following example:
      # flarcreate -n S10U5hybrid -U "content_architectures=sun4u,sun4v" \
      -c -x /data /data/S10U5hybrid.flar
      The above sample command provides /data for the -c option, to indicate the location for the archive. Your value for this -c option should reflect your file setup.
      Note –
      You can verify that the Sun4V platform group is supported by using the flar command again as shown in the previous step.
  2. Install the Solaris Flash archive on the Sun4V machine. You can use Solaris JumpStart and a net image to deploy the Solaris Flash archive.
    Note –
    At this point, the Sun4V machine may not boot. Do not try to patch the machine at this stage. If the machine is allowed to reboot after using JumpStart, you will probably see a message such as:
    Boot device: /pci@780/pci@0/pci@9/scsi@0/disk@0,0:a  File and args:
    Boot load failed.
    The file just loaded does not appear to be executable.
  3. Upgrade the Sun4V machine using either a network image or a DVD image.
    For example, you could use a Solaris 10 Update 6 JumpStart image. Then, you could boot the Sun4V image from that network image, selecting the upgrade option.
    In this example, the upgrade completes with the following issues:
    • Where both .u and .v versions of a package were available, both versions will be installed. See CR 6846077.
    • The /var/sadm/system/admin/.platform file contains incorrect information. See CR 6523030.
    • Any third party .v packages are not part of the Solaris image. So, third party packages will probably not be upgraded.
  4. Boot the Sun4V machine. You can now apply patches to the machine as needed.
Customizing the Solaris Installation on the Master System
After you install the Solaris OS on the master system by using any of the Solaris installation methods, you can add or delete software and modify system configuration information as necessary. To customize the master system's software, you can do the following:
Creating Archives for SPARC and x86 Systems
If you want to install Solaris software by using a Solaris Flash archive on both SPARC and x86 systems, you must create a separate Solaris Flash archive for each platform. Use the Solaris Flash archive that was created from the SPARC master system to install SPARC systems. Use the Solaris Flash archive that was created from the x86 master system to install x86 systems.
Choosing the drivers to install on the master system has the following dependencies.
The Entire Plus OEM Software Group installs all drivers regardless of the hardware that is present on the system. Other software groups provide limited support. If you install another software group and the clone systems have different peripheral devices than the master system, you need to install the appropriate drivers on the master system before you create the archive.
How to Get the Support for Peripherals That You Need
You can install support for peripherals on clone systems that are different from the master system in by installing the Entire Plus OEM Software Group or installing selected packages.
Type of Installation
Description
Install the Entire Plus OEM Software Group
The Entire Plus OEM Software Group is the largest Software Group available. This group contains every package that is found in the Solaris OS. The Entire Plus OEM Software Group installs all drivers regardless of the hardware that is present on the system. A Solaris Flash archive that is created with the Entire Plus OEM Software Group works on any clone system that has peripheral devices supported by the installed release of the Solaris OS.
Installing master systems with the Entire Plus OEM Software Group guarantees compatibility with other peripheral configurations. However, the Entire Plus OEM Software Group requires at least 2.9 Gbytes of disk space. The clone systems might not have the space that is required to install the Entire Plus OEM Software Group.
Install other software groups
If you install the master system with the following software groups, you are limiting the support for peripherals. The master system supports only the peripheral devices that are attached to the master system at the time of installation.
  • Reduced Networking Software Group
  • Core Software Group
  • End User Software Group
  • Developer Software Group
  • Entire Software Group
Installing these software groups could result in your clone systems failing to have all the drivers needed. For example, if you install the Entire Software Group on a master system that has a GX CG6 frame buffer, only the GX CG6 frame buffer driver is installed. This situation is not a problem if all the clone systems that you want to install have the GX CG6 frame buffer or no frame buffer.
Install selected packages
When you install the master system, you can install only the packages that you need for the master system and the clone systems. By selecting specific packages, you can install only support for the peripherals that you know exist on the master system or clone systems.
Planning the Creation of a Solaris Flash Archive
You can create an archive from the master system for an initial installation. Or, if you have already installed an archive on clone systems, you can create a differential archive from two system images. The differential archive installs only the differences between the two images.
Planning to Create the Solaris Flash Archive for an Initial Installation
After you install the master system, the next task in the Solaris Flash installation process is to create a Solaris Flash archive. Files on the master system are copied to a Solaris Flash archive along with various pieces of identification information. You can create a Solaris Flash archive while the master system is running in multiuser mode or single-user mode. You can also create a Solaris Flash archive after you boot from one of the following:
Caution – Caution –
A Solaris Flash archive cannot be properly created when a non-global zone is installed. The Solaris Flash feature is not compatible with the Solaris Zones partitioning technology. If you create a Solaris Flash archive, the resulting archive is not installed properly when the archive is deployed under these conditions:
Creating Solaris Flash Archives With RAID-1 Volumes
You can create a Solaris Flash archive when you have aSolaris Volume Manager RAID-1 volumes configured. The Solaris Flash creation software removes all RAID-1 volume information from the archive to keep the integrity of the clone system. With custom JumpStart you can rebuild the RAID-1 volumes by using a JumpStart profile. With Solaris Live Upgrade, you create a boot environment with RAID-1 volumes configured and install the archive. The Solaris installation program cannot be used to install RAID-1 volumes with a Solaris Flash archive.
Note –
Veritas VxVM stores configuration information in areas not available to Solaris Flash. If Veritas VxVm file systems have been configured, you should not create a Solaris Flash archive. Also, Solaris install, including JumpStart and Solaris Live Upgrade do not support rebuilding VxVM volumes at installation time. Therefore, if you are planning to deploy Veritas VxVM software using a Solaris Flash archive, the archive must be created prior to configuring the VxVM file systems. The clone systems must be then configured individually after the archive has been applied and the system rebooted.
Creating an Archive That Contains Large Files
The default copy method that is used when you create a Solaris Flash archive is the cpio utility. Individual file sizes cannot be over 4 Gbytes. If you have large individual files, you can create an archive with the pax copy method. The flarcreate command with the -L pax option uses the pax utility to create an archive without limitations on individual file sizes. Individual file sizes can be greater than 4 Gbytes.
If you have a clone system that is already installed with an archive and want to update it, you can create a differential archive that contains only the differences between two images, the unchanged master image and an updated master image. The differences between these two images is the differential archive.
After you update a clone system with a differential archive, only the files that are in the differential archive are changed on the clone system. Scripts can be used to customize the archive before or after installation, which is especially helpful for reconfiguration.
You can install a Solaris Flash differential archive with the custom JumpStart installation method. Or, you can use Solaris Live Upgrade to install a differential archive on an inactive boot environment.
An unchanged master image should be saved after the initial installation so this image can be accessed by any of the following methods.
For step-by-step instructions, see To Create a Solaris Flash Differential Archive With an Updated Master Image.
Customizing an Archive's Files and Directories
When you create a Solaris Flash archive, some files and directories that are to be copied from the master system can be excluded. If you have excluded a directory, you can also restore specified files or subdirectories under that directory. For example, you could create an archive that excludes all files and directories in /a/aa/bb/c. The content of the bb subdirectory could be included. The only content would then be in the bb subdirectory.
Caution – Caution –
Use the flarcreate file-exclusion options with caution. If you exclude some directories, others that you were unaware of might be left in the archive, such as system configuration files. The system would then be inconsistent and the installation would not work. Excluding directories and files is best used with data that can easily be removed without disrupting the system, such as large data files.
The following table lists the flarcreate command options that can exclude files and directories and restore files and subdirectories.
How Specified?
Options That Exclude
Options That Include
Specify the name of the directory or file
-x exclude_dir/filename
-y include_dir/filename
Use a file that contains a list
-X list_filename
-z list_filename
-f list_filename
-z list_filename
For descriptions of these options, see Table 5–7.
For examples of customizing an archive, see Creating a Solaris Flash Archive and Customizing Files (Examples).
Customizing an Archive With Scripts
After the software is installed on the master system, special scripts can be run during creation, installation, postinstallation and first reboot. These scripts enable you to do the following:
Guidelines for Creating a Custom Script
When creating scripts other than the reboot script, following these guidelines to assure the script does not corrupt the OS or otherwise disrupt the system. These guidelines enable the use of Solaris Live Upgrade, which creates a new boot environment for installation of the OS. The new boot environment can be installed with an archive while the current system is running.
Note –
These guidelines are not for reboot scripts that are allowed to run daemons or make other types of modification to the root (/) file system.
For an overview of Solaris Live Upgrade, see Chapter 2, Solaris Live Upgrade (Overview), in Solaris 10 5/09 Installation Guide: Solaris Live Upgrade and Upgrade Planning.
Solaris Flash Archive Sections
Solaris Flash archives contain the following sections. Some sections can be used by you to identify and customize the archive and view status information on the installation. For a further description of each section, see Chapter 5, Solaris Flash (Reference).
Table 2–2 Flash Archive Sections
Section Name
Informational Only
Description
Archive cookie
X
The first section contains a cookie that identifies the file as a Solaris Flash archive.
Archive identification
The second section contains keywords with values that provide identification information about the archive. Some identification information is supplied by the archive software. Other specific identification information can be added by you with options to the flarcreate command.
User-defined
This section follows the archive identification section. You can define and insert these sections to customize the archive. The Solaris Flash archive does not process any sections that you insert. For example, a section could contain a description of the archive or perhaps a script to check the integrity of an application.
Manifest
X
This section is produced for a Solaris Flash differential archive and is used for validating a clone system. The manifest section lists the files on a system to be retained, added to, or deleted from the clone system. This section is informational only, lists the files in an internal format, and cannot be used for scripting.
Predeployment, Postdeployment, Reboot
X
This section contains internal information that the flash software uses before and after installing an OS image. Any scripts that you have provided are included in this section.
Summary
This section contains messages about the archive creation. The section also records the activities of predeployment and postdeployment scripts. You can view the success of the installation in this section by writing a script to send output to this section.
Archive files
X
The archive files section contains the files that have been gathered from the master system.
When to Create the Archive for an Initial Installation
Create the archive when the system is in as static a state as possible. Create the archive after software is installed on the master system and before software is configured.
Where to Store the Solaris Flash Archive
After you create the Solaris Flash archive, you can save the archive on the hard disk of the master system or on a tape. After you save the archive, you can copy this archive to any file system or media that you choose.
Compressing the Archive
When you create the Solaris Flash archive, you can specify that the archive be saved as a compressed file by using the compress(1) utility. An archive that is compressed requires less disk storage space and creates less congestion when you install the archive over a network.
Planning the Installation of Solaris Flash Archives
The final task in the Solaris Flash installation process is to install Solaris Flash archives on clone systems. You can use any of the Solaris installation methods to install Solaris Flash archives on clone systems.
Installation Program
Archives Storable on This Media
For Step-by-Step Instructions
  • NFS server
  • HTTP server
  • FTP server
  • Local tape
  • Local device, including DVD or CD
  • Local file
Installing a Solaris Flash Archive With the Solaris Installation Program
Custom JumpStart installation program
  • NFS server
  • HTTP or HTTPS server
  • FTP server
  • Local tape
  • Local file
To Prepare to Install a Solaris Flash Archive With a Custom JumpStart Installation in Solaris 10 5/09 Installation Guide: Custom JumpStart and Advanced Installations
  • NFS server
  • HTTP server
  • FTP server
  • Local tape
  • Local file
Installing Solaris Flash Archives on a Boot Environment in Solaris 10 5/09 Installation Guide: Solaris Live Upgrade and Upgrade Planning
