Solaris 10 10/09 What's New summarizes all features in the SolarisTM 10 Operating System (OS) that are new or have been enhanced in the Solaris 10 10/09 OS.
This Solaris release supports systems that use the SPARC® and x86 families of processor architectures. The supported systems appear in the Solaris OS: Hardware Compatibility Lists. This document cites any implementation differences between the platform types.
In this document these x86 related terms mean the following:
“x86” refers to the larger family of 64-bit and 32-bit x86 compatible products.
“x64” relates specifically to 64-bit x86 compatible CPUs.
“32-bit x86” points out specific 32-bit information about x86 based systems.
For supported systems, see the Solaris OS: Hardware Compatibility Lists.
This book provides introductory descriptions of the new Solaris 10 features for users, developers, and system administrators who install and use the Solaris 10 Operating System.
Certain optional features and products that are described in this document might require individual licensing for use. Refer to the Software License Agreement.
For further information about the features that are summarized in this book, refer to the following Solaris 10 documentation at http://docs.sun.com/app/docs/prod/solaris.10.
Third-party URLs are referenced in this document and provide additional, related information.
Sun is not responsible for the availability of third-party Web sites mentioned in this document. Sun does not endorse and is not responsible or liable for any content, advertising, products, or other materials that are available on or through such sites or resources. Sun will not be responsible or liable for any actual or alleged damage or loss caused by or in connection with use of or reliance on any such content, goods, or services that are available on or through such sites or resources.
The Sun web site provides information about the following additional resources:
Sun is interested in improving its documentation and welcomes your comments and suggestions. To share your comments, go to http://docs.sun.com and click Feedback.
The following table describes the typographic conventions that are used in this book.
Table P–1 Typographic Conventions|
Typeface |
Meaning |
Example |
AaBbCc123 |
The names of commands, files, and directories, and onscreen computer output |
Edit your .login file. Use ls -a to list all files. machine_name% you have mail. |
AaBbCc123 |
What you type, contrasted with onscreen computer output |
machine_name% su Password: |
aabbcc123 |
Placeholder: replace with a real name or value |
The command to remove a file is rm filename. |
AaBbCc123 |
Book titles, new terms, and terms to be emphasized |
Read Chapter 6 in the User's Guide. A cache is a copy that is stored locally. Do not save the file. Note: Some emphasized items appear bold online. |
The following table shows the default UNIX® system prompt and superuser prompt for the C shell, Bourne shell, and Korn shell.
Table P–2 Shell Prompts|
Shell |
Prompt |
C shell |
machine_name% |
C shell for superuser |
machine_name# |
Bourne shell and Korn shell |
Bourne shell and Korn shell for superuser |
