Solaris 10 10/09 Installation Guide: Solaris Flash Archives (Creation and Installation)
Creating Customization Scripts
Scripts can customize the archive. Use these scripts for the following purposes:
For guidelines about creating scripts, see Guidelines for Creating a Custom Script.
ProcedureTo Create a Precreation Script
This script runs during archive creation. The script has various uses.
  1. Create the precreation script. Follow the guidelines that are described in Guidelines for Creating a Custom Script.
  2. Store the script in the /etc/flash/precreation directory.
Example 3–1 Excerpts From a Precreation Script
The following examples are excerpts from a precreation script.
Example 3–2 Precreation Script
#!/bin/sh
echo "Test precreation script started" >> $FLASH_DIR/summary
cat /opt/TestApp/critical_file_list | flcheck -
if [ $? != 0 ]; then
	echo "Test precreation script failure" >> $FLASH_DIR/summary
	exit 1
fi
/opt/TestApplication/license_cloning
	$FLASH_DIR/predeployment/.TestApplicationLicenceTransfer \
	$FLASH_DIR/custom_sections/TestApplicationLicenceCounter
echo "Test precreation script finished" >> $FLASH_DIR/summary
exit 0
Using a Precreation Script to Create a User-Defined Archive Section
A precreation script can create a user-defined section in the archive to provide specific application information. This section is intended for archive maintenance. The script must be put in the $FLASH_DIR/sections directory. The Solaris Flash archive does not process a user-defined section. For example, a section could contain a description of the archive or perhaps a script to check the integrity of an application.
A user-defined section requires the following format.
ProcedureTo Create a Predeployment Script
This script is run before the installation of the archive. If the script is meant to validate the archive, it is kept in the archive. If the script is meant to preserve local configurations on the clone system, it is kept on the clone system. This script also can analyze and collect local data necessary for later customization. For example, client-specific information can be saved before being overwritten by files about to be extracted. This information can then be used in the final stage after extraction.
  1. Create the predeployment script. Follow the guidelines that are described in Guidelines for Creating a Custom Script.
  2. Store the script in one of the following directories.
    • For archive validation, store in the /etc/flash/predeployment directory.
    • If you are referencing with a precreation script, store in the $FLASH_DIR/preinstall directory.
    • If you are preserving configurations on a clone system, provide the path to the script that is stored on the clone system with the local_customization keyword in the JumpStart profile.
Example 3–3 Predeployment Script
#!/bin/sh
$FLASH_DIR/TestApplication/check_hardware
	echo Unsupported hardware
	exit 1
fi
$FLASH_DIR/TestApplication/check_licence_key
	echo No license for this host
	exit 1
fi
$FLASH_DIR/TestApplication/deploy_license_key \
	$FLASH_DIR/TestApplication/.TestApplicationLicenceTransfer
$FLASH_DIR/TestApplication/save_data_files $FLASH_DIR/flash
exit 0
ProcedureTo Create a Postdeployment Script
This script is kept in the archive or stored in a local directory on the clone system and runs after installation. The script reconfigures a new system image on a clone system. If the script is stored in the archive, the changes affect all the clone systems. If the script is stored in a local directory on the clone system, the changes affect only the clone system. For example, client-specific information that is saved by a predeployment script can be applied to the clone environment, completing the installation.
Postdeployment scripts can also be used to clean up files after the archive is installed. For example, log files such as those files in /var/adm can be cleaned out.
Note –
Not all log files need a script for cleanup. Log files in /var/tmp can be excluded when the archive is created.
  1. Create the postdeployment script. Follow the guidelines that are described in Guidelines for Creating a Custom Script.
    • To affect all clone systems, store the script in the /etc/flash/postdeployment directory.
    • To affect only a local clone system, provide the path to the script that is stored on the clone system with the local_customization keyword in the JumpStart profile.
Example 3–4 Postdeployment Script
#!/bin/sh
$FLASH_DIR/TestApplication/clone_reconfiguration
$FLASH_DIR/TestApplication/restore_data $FLASH_DIR/flash
ProcedureTo Create a Reboot Script
This script is kept in the archive and runs after the system is rebooted. The script does any final configuration after system reconfiguration.
After you install the Solaris Flash archive on a clone system, some host-specific files are deleted and are re-created for the clone machine. The installation program uses the sys-unconfig(1M) command and the sysidtool(1M) programs to delete and re-create host-specific network configuration files. The files that are re-created include, for example, /etc/hosts, /etc/defaultrouter, and /etc/defaultdomain. You can use the reboot script for any final reconfiguration.
  1. Create the reboot script.
  2. Store the script in the /etc/flash/reboot directory.
Example 3–5 Creating a reboot Script
#!/bin/sh
$FLASH_DIR/TestApplication/finalize_license
