The rule and probe keywords that are described in Rule Keywords and Values and Probe Keywords and Values might not be precise enough for your needs. You can define your own custom rule or probe keywords by creating a custom_probes file.
The custom_probes file is a Bourne shell script that contains two types of functions. You must save the custom_probes file in the same JumpStart directory where you saved the rules file. The two types of functions that you can define in a custom_probes file are as follows:
Probe – Gathers the information you want or does the actual work and sets a corresponding SI_ environment variable that you define. Probe functions become probe keywords.
Comparison – Calls a corresponding probe function, compares the output of the probe function, and returns 0 if the keyword matches or 1 if the keyword does not match. Comparison functions become rule keywords.
The custom_probes file can contain any valid Bourne shell command, variable, or algorithm.
You can define probe and comparison functions that require a single argument in the custom_probes file. When you use the corresponding custom probe keyword in the rules file, the argument after the keyword is interpreted (as $1).
When you use the corresponding custom rule keyword in the rules file, the arguments are interpreted in sequence. The sequence starts after the keyword and ends before the next && or begin script, whichever comes first.
The custom_probes file must meet the following requirements:
Have root as its owner
Be executable and have permissions set to 755
Contain at least one probe function and one corresponding comparison function
To improve clarity and organization, define all probe functions first, at the top of the file, followed by all comparison functions.
The name of a probe function must begin with probe_. The name of a comparison function must begin with cmp_.
Functions that begin with probe_ define new probe keywords. For example, the function probe_tcx defines the new probe keyword tcx. Functions that begin with cmp_ define new rule keywords. For example, cmp_tcx defines the new rule keyword tcx.
Use a text editor to create a Bourne shell script text file. Name the file custom_probes.
In the custom_probes text file, define your probe and comparison functions.
You can define probe and comparison functions that require arguments in the custom_probes file. When you use the corresponding custom probe keyword in the rules file, the arguments after the keyword are interpreted in sequence (as $1, $2, and so on).
Save the custom_probes file in the JumpStart directory next to the rules file.
Ensure that root owns the rules file and that the permissions are set to 644.
You can find additional examples of probe and comparison functions in the following directories:
/usr/sbin/install.d/chkprobe on a system that has the Solaris software installed
/Solaris_10/Tools/Boot/usr/sbin/install.d/chkprobe on the Solaris Operating System DVD or on the Solaris Software - 1 CD
The following custom_probes file contains a probe and comparison function that tests for the presence of a TCX graphics card.
#!/bin/sh # # custom_probe script to test for the presence of a TCX graphics card. # # # PROBE FUNCTIONS # probe_tcx() { SI_TCX=`modinfo | grep tcx | nawk '{print $6}'` export SI_TCX } # # COMPARISON FUNCTIONS # cmp_tcx() { probe_tcx if [ "X${SI_TCX}" = "X${1}" ]; then return 0 else return 1 if } |
The following example rules file shows the use of the probe keyword that is defined in the preceding example, tcx. If a TCX graphics card is installed and found in a system, profile_tcx is run. Otherwise, profile is run.
Always place probe keywords at or near the beginning of the rules file. This placement ensures that the keywords are read and run before other rule keywords that might rely on the probe keywords.
probe tcx tcx tcx - profile_tcx - any any - profile - |
