Sun Java System Directory Server Enterprise Edition 6.3 Administration Guide
ProcedureTo Create a Suffix for a Hub Replica
  1. If an empty suffix does not already exist, create it on the hub server with the same DN as the intended master replica.
    For instructions, see Creating Suffixes.
    If the suffix exists and is not empty, its contents will be lost when the replicated suffix is initialized from the master.
