This appendix describes the files found after you install Directory Server Resource Kit. You can also find lists of installed files in the install-path/dsee6/data/ directory.
The examples shown in this appendix are for Solaris systems. File extensions and path separators may differ for your operating system.
This section describes the file layout you find after installing Directory Server Resource Kit from the zip distribution. All files locations are relative to the path where you installed the product. For information on default native package installation locations, see Default Paths and Command Locations.
Files shared by multiple Directory Server Enterprise Edition component products. This directory houses the following files of interest.
NSS certificate manipulation command used by other tools, not intended to be used directly.
Command to install and remove software. See dsee_deploy(1M).
Command to base64 encode LDIF attribute values. See ldif(1)
Common agent container files shared by Directory Server Enterprise Edition component products, not intended to be used directly.
Lists of installed files used by the dsee_deploy command, not intended to be used directly.
Libraries shared by Directory Server Enterprise Edition component products, not intended to be used directly.
Directory Server Enterprise Edition online reference manual pages. See also Sun Java System Directory Server Enterprise Edition 6.3 Man Page Reference.
Directory Server Resource Kit command to measure authentication rate. See authrate(1).
Directory Server Resource Kit command to update entries using DSML v2. See dsmlmodify(1).
Directory Server Resource Kit command to search a directory using DSML v2. See dsmlsearch(1).
Sample template files for use with the makeldif.
Directory Server Resource Kit command to compare LDAP entries from two directories. See ldapcmp(1).
Directory Server Resource Kit command to perform LDAP compare operations. See ldapcompare(1).
Directory Server Resource Kit command to delete directory entries. See ldapdelete(1).
Directory Server Resource Kit command to update entries over LDAP. See ldapmodify(1).
Directory Server Resource Kit command to change user passwords. See ldappasswd(1).
Directory Server Resource Kit command to search a directory. See ldapsearch(1).
Directory Server Resource Kit command to delete a directory subtree recursively. See ldapsubtdel(1).
Directory Server Resource Kit command to transform LDIF content. See ldifxform(1).
Directory Server Resource Kit command to analyze Directory Server access logs. See logconv(1).
Directory Server Resource Kit command to generate LDIF content for testing and benchmarking purposes. See makeldif(1).
Directory Server Resource Kit command to measure rates of modifications to directory entries. See modrate(1).
Directory Server Resource Kit command to measure search rates. See searchrate(1).
Libraries used by Directory Server Resource Kit commands, not intended to be used directly.
