NAME | Description | Examples | Attributes
 PROPERTY  |
 VALUE  |
 Entry DN  |
 cn=config  |
 Valid Range  |
 See the description that follows.  |
 Default Value  |
 256  |
 Syntax  |
 Integer  |
This attribute specifies the access log levels. Log levels can be added together to provide you with the exact type of logging you require. For example, 516 (4 + 512) obtains the internal access operation, entry access, and referral logging. The following levels are supported:
No access logging
Logging for internal access operations
Logging for access to an entry
Logging for access to an entry and referrals
Precise timing of operation duration. This gives microsecond resolution for the elapsed time item in the access log.
nsslapd-accesslog-level: 256
 ATTRIBUTE TYPE  |
 ATTRIBUTE VALUE  |
 Availability  |
 SUNWldap-directory  |
 Stability Level  |
 Unstable  |
