Sun Cluster Data Services Developer's Guide for Solaris OS
Using Keep-Alives
On the server side, using TCP keep-alives protects the server from wasting system resources for a down (or network-partitioned) client. If these resources are not cleaned up (in a server that stays up long enough), eventually the wasted resources grow without bound as clients crash and reboot.
If the client-server communication uses a TCP stream, then both the client and the server should enable the TCP keep-alive mechanism. This provision applies even in the non-HA, single-server case.
Other connection-oriented protocols might also have a keep-alive mechanism.
On the client side, using TCP keep-alives enables the client to be notified when a network address resource has failed over or switched over from one physical host to another. That transfer of the network address resource breaks the TCP connection. However, unless the client has enabled the keep-alive, it does not necessarily learn of the connection break if the connection happens to be quiescent at the time.
For example, suppose the client is waiting for a response from the server to a long-running request, and the client's request message has already arrived at the server and has been acknowledged at the TCP layer. In this situation, the client's TCP module has no need to keep retransmitting the request, and the client application is blocked, waiting for a response to the request.
Where possible, in addition to using the TCP keep-alive mechanism, the client application also must perform its own periodic keep-alive at its level, because the TCP keep-alive mechanism is not perfect in all possible boundary cases. Using an application-level keep-alive typically requires that the client-server protocol supports a null operation or at least an efficient read-only operation such as a status operation.
