Problem Summary: The data services for the following applications cannot be upgraded by using the scinstall utility:
Apache Tomcat
DHCP
mySQL
Oracle E-Business Suite
Samba
SWIFTAlliance Access
WebLogic Server
WebSphere MQ
WebSphere MQ Integrator
Workaround: If you plan to upgrade a data service for an application in the preceding list, replace the step for upgrading data services in “Upgrading to Sun Cluster 3.1 4/04 Software (Rolling)” in Sun Cluster Software Installation Guide for Solaris OS with the steps that follow. Perform these steps for each node where the data service is installed.
Remove the software package for the data service that you are upgrading.
# pkgrm pkg-inst |
pkg-inst specifies the software package name for the data service that you are upgrading as listed in the following table.
Application |
Data Service Software Package |
Apache Tomcat |
SUNWsctomcat |
DHCP |
SUNWscdhc |
mySQL |
SUNWscmys |
Oracle E-Business Suite |
SUNWscebs |
Samba |
SUNWscsmb |
SWIFTAlliance Access |
SUNWscsaa |
WebLogic Server (English locale) |
SUNWscwls |
WebLogic Server (French locale) |
SUNWfscwls |
WebLogic Server (Japanese locale) |
SUNWjscwls |
WebSphere MQ |
SUNWscmqs |
WebSphere MQ Integrator |
SUNWscmqi |
Install the software package for the version of the data service to which you are upgrading.
To install the software package, follow the instructions in the Sun Cluster documentation for the data service that you are upgrading. This documentation is available at http://docs.sun.com.
