Problem Summary: SunPlex Manager includes a data service installation wizard that sets up a highly available DNS service on the cluster. If the user does not supply an existing DNS configuration, such as a named.conf file, the wizard attempts to generate a valid DNS configuration by autodetecting the existing network and nameservice configuration. However, it fails in some network environments, causing the wizard to fail without issuing an error message.
Workaround: When prompted, supply the SunPlex Manager DNS data service install wizard with an existing, valid named.conf file. Otherwise, follow the documented DNS data service procedures to manually configure highly available DNS on the cluster.
