If you are using Sun Cluster HA for Oracle with Oracle 10g, do not install the Oracle binary files on a highly available local file system. Sun Cluster HA for Oracle does not support such a configuration. However, you may install data files, log files, and configuration files on a highly available file system.
If you have installed Oracle 10g binary files on the cluster file system, error messages for the Oracle cssd daemon might appear on the system console during the booting of a node. When the cluster file system is mounted, these messages no longer appear.
These error messages are as follows:
INIT: Command is respawning too rapidly. Check for possible errors. id: h1 "/etc/init.d/init.cssd run >/dev/null 2>&1 >/dev/null" |
Sun Cluster HA for Oracle does not require the Oracle cssd daemon. Therefore, you may ignore these error messages.
