Problem Summary: Due to an internal error, most Sun-supplied cluster agents are writing messages to the system log (see syslog(3C)) using the LOG_USER facility instead of using LOG_DAEMON. On a cluster that is configured with the default syslog settings (see syslog.conf(4)), messages with a severity of LOG_WARNING or LOG_NOTICE, which would ordinarily be written to the system log, are not being output.
Workaround: Add the following line near the front of the /etc/syslog.conf file on all cluster nodes:
user.warning /var/adm/messages |
