This section discusses errors and omissions in SunPlex Manager online help.
In the online help file that is titled “Sun Cluster HA for Oracle,” in the section titled “Before Starting,” a note is incorrect.
Incorrect:
If no entries exist for shmsys and semsys in /etc/system, default values for these variables are automatically inserted in/etc/system. The system must then be rebooted. Check Oracle installation documentation to verify that these values are correct for your database.
Correct:
If no entries exist for the shmsys and semsys variables in the /etc/system file when you install the Oracle data service, you can open /etc/system and insert default values for these variables. You must then reboot the system. Check Oracle installation documentation to verify that the values that you insert are correct for your database.
In the table under "Sun Cluster RBAC Rights Profiles," the authorizations solaris.cluster.appinstall and solaris.cluster.install should be listed under the Cluster Management profile rather than the Cluster Operation profile.
In the table under “Sun Cluster RBAC Rights Profiles,” under the profile Sun Cluster Commands, sccheck(1M) should also be included in the list of commands.
