# Extension Properties # # The cluster administrator must set the value of this property to point to the # directory that contains the configuration files used by the application. # For this application, smpl, specify the path of the configuration file on # PXFS (typically named.conf). { PROPERTY = Confdir_list; EXTENSION; STRINGARRAY; TUNABLE = AT_CREATION; DESCRIPTION = "The Configuration Directory Path(s)"; } # The following two properties control restart of the fault monitor. { PROPERTY = Monitor_retry_count; EXTENSION; INT; DEFAULT = 4; TUNABLE = ANYTIME; DESCRIPTION = "Number of PMF restarts allowed for fault monitor."; } { PROPERTY = Monitor_retry_interval; EXTENSION; INT; DEFAULT = 2; TUNABLE = ANYTIME; DESCRIPTION = "Time window (minutes) for fault monitor restarts."; } # Time out value in seconds for the probe. { PROPERTY = Probe_timeout; EXTENSION; INT; DEFAULT = 120; TUNABLE = ANYTIME; DESCRIPTION = "Time out value for the probe (seconds)"; } # Child process monitoring level for PMF (-C option of pmfadm). # Default of -1 means to not use the -C option of pmfadm. # A value of 0 or greater indicates the desired level of child-process. # monitoring. { PROPERTY = Child_mon_level; EXTENSION; INT; DEFAULT = -1; TUNABLE = ANYTIME; DESCRIPTION = “Child monitoring level for PMF"; } # User added code -- BEGIN VVVVVVVVVVVV # User added code -- END ^^^^^^^^^^^^
Agent Builder 创建了一些对大多数的数据服务都有用的扩展特性,如下所示。
指定应用程序配置目录的路径,这对于很多应用程序是有用的信息。 配置数据服务时,系统管理员可以提供此目录的位置。
用于控制故障监视器本身的重启操作,而不是服务器守护程序的重启操作。
用于设置 PMF 要完成的监视操作的级别。 有关详细信息,请参阅 pmfadm(1M)。
您可以在由用户添加的代码注释分隔的区域内创建其它扩展特性。
