Skip Navigation Links
Exit Print View
Sun Ethernet Fabric Operating System
XVLAN Administration Guide
search filter icon
search icon
Document Information
Using This Documentation
Product Notes
Related Documentation
Acronyms and Abbreviations
CLI Command Modes
Feedback
Support and Accessibility
Protocol Description
Principal XVLAN
Restricted XVLAN
XVLAN Port Types
Supported CLI Commands
Configuring XVLAN
Single-Switch Configuration
Single-Switch Topology
Configure External and Internal Ports in a Solitary-Restricted XVLAN
Configure Ports in Solitary- and Group-Restricted XVLANs
Allowing Regular VLAN on XVLAN Ports
Configure Regular VLAN on an XVLAN Port
Display Port VLAN Properties
Configure Regular VLAN 100 With Ports Used in an XVLAN
Multiple-Switch Configuration
Multiple-Switch Topology
Connect Two Switches With Two Restricted XVLANs
Connect XVLANs Across SEFOS1 and SEFOS2
These sections describe the multiple-switch configuration:
