Verifying DCB and LLDP Configurations
Determine Whether Interfaces Are Active
Determine Whether LLDP is Running and Recognizing Peers
Disable DCB for Each Interface
Enable and Disable a Specific DCB Feature
Configure the Mode for the DCB Feature
Display DCBX Feature Statistics and Control Information
Display Output of Unstarted DCBX Protocol Exchange
Display Output of DCBX TLV Exchange
For late-breaking information and known issues about the following products, refer to the product notes at:
Sun Blade 6000 Ethernet Switched NEM 24p 10GbE:
http://www.oracle.com/pls/topic/lookup?ctx=SB6K-24p-10GbE
Sun Network 10GbE Switch 72p:
