Skip Navigation Links | |
Exit Print View | |
Sun Ethernet Fabric Operating System IPv6 Administration Guide |
Route Redistribution Topology in IPv6
Completing Preliminary Configurations
Configure an IPv4 Address for an Interface
Configuring the Basic IPv6 Topology
Configuring the Route Redistribution Topology
Configuring IPv6 Support in an Interface
Add IPv6 Addresses to an Interface
Remove IPv6 Addresses From an Interface
Configuring IPv6 Static Routes
Configuring Static Neighbor Cache Entries
Checking a Local or Remote Endpoint
Check an Endpoint Using Default Values
Check an Endpoint Using the Link-Local Address
Configuring Router Advertisement Parameters
Configure Router Advertisement Parameters
Setting the MTU for Use in PMTU Discovery
Set the MTU for Use in PMTU Discovery
Configure the IPv6 Route Resitribution Policy for Routing Protocols
The RRD policy feature uses a routing protocol to advertise routes that are learned by other routing protocols. The routes can be static routes or directly connected routes. This procedure shows how to configure the policy set for routing IPv6 routes. The IPv6 routes are maintained in the RTM6 table that is used for IPV6 routes, ensuring that the route table manager redistributes the best route.
This procedure shows how to configure the IPv6 route redistribution policy for routing protocols:
