To use external VGA with SunPCi, type the following command at the system prompt:
% sunpci -vga
To use SunPCi with the on-board (workstation) video, just type the standard sunpci command at the system prompt. Table 4–1 describes the type of video output that occurs for the operating system you want to use, the video driver you have installed, and whether or not you typed sunpci -vga at the prompt.
Table 4–1 Video Options Matrix|
PC Operating System |
VGA Monitor Connected |
VGA Monitor Not Connected |
DOS (-vga switch used) |
Video is routed to VGA monitor |
Video discarded; SunPCi window displays “Video routed” message |
DOS (-vga switch not used) |
Video is routed to SunPCi window on workstation screen |
Windows 95 VGA driver used |
Video discarded |
Windows 95 SunPCi drivers installed |
Windows NT (SunPCi drivers installed automatically) |
Video is routed to SunPCi window on workstation screen; to use external monitor, install the sis5598 driver.
If you have the VGA driver installed but do not have an external VGA monitor attached, and you want to install the SunPCi drivers for Windows 95, you can follow the instructions in Chapter 3, Starting SunPCi Software for the First Time for installing the SunPCi drivers.
