If you are running an earlier version of Windows 95 (for example, Windows 95b), your operating system software does not automatically support USB (Universal System Bus) devices. You will need to install the Windows 95 USB driver usbsupp.exe before using USB devices with SunPCi. Figure 4–1 shows the location of the USB port on the backplate of the SunPCi board.
Windows NT 4.0 does not support USB devices. The usbsupp.exe driver works only with Windows 95.
If you do not know which version of Windows 95 you have installed on SunPCi, follow these steps. You need to know the version number before you can install the USB driver.
On the Windows 95 desktop, click the right mouse button on the My Computer icon.
The pop-up menu is displayed.
Select Properties, and then click on the General tab.
Your Windows 95 version is displayed. If the version number is 4.00.950B or higher, you will be able to install the USB driver. If the version number is not 4.00.950B or higher, you will need to upgrade your copy of Windows 95 before you can use USB devices.
The usbsupp.exe driver is located on the Windows 95 OEM Service Release CD-ROMs version 2.1 and 2.5 at drive:\Other\USB Folder (where drive: is the drive letter for your CD drive). If you do not have the CD-ROM available, you can download the driver from the World Wide Web at http://www.microsoft.com/HWDEV/devdes/usbgame.htm. Save the file to a floppy disk or to a temporary location on your C: drive, such as C:\temp.
To install the driver, follow this procedure:
Click the Start button, and then choose Programs and Windows Explorer from the pop-up menus.
The Exploring window is displayed.
Locate the file USBSUPP.EXE and double-click on the icon.
Follow the instructions on the screen to install the driver.
After Windows 95 restarts, you should be able to use USB devices with Windows 95.
The README.TXT file included with the driver contains information on how to uninstall and reinstall the driver, if necessary. It also describes how to consult the Microsoft Knowledge Base for more information on the USB driver.
