There are two Solaris commands—/usr/bin/dos2unix and /usr/bin/unix2dos—that enable you to specify code pages. For example, to convert the task_list file, created with code page 850, from a DOS to a Solaris format, use the dos2unix command, and enter the following:
C:\> dos2unix -850 task_list task_list
If the code page is not specified on the command line, dos2unix and unix2dos will check the $LANG environment variable to determine which code page to use. To check whether your $LANG variable is set, enter the following in a Solaris command window:
% env | grep LANG
If you do not have the $LANG variable set, or if it is set to anything but the settings listed in Table B–4, SunPCi software uses the default US code page 437 and the en_US (English-US) $LANG setting.
Table B–4 $LANG Variable Settings|
$LANG Variable Setting |
Language/Territory |
C |
Default “C” locale |
es_AR |
Arabic |
da |
Danish |
de |
German |
de_AT |
Austrian German |
de_CH |
Swiss German |
el |
Greek |
en_AU |
Australian English |
en_IE |
Irish English |
en_NZ |
New Zealand English |
en_UK |
UK English |
en_US |
US English |
es |
Spanish |
es_BO |
Bolivian Spanish |
es_CL |
Chilean Spanish |
es_CO |
Colombian Spanish |
es_CR |
Costa Rican Spanish |
es_EC |
Ecuadorian Spanish |
es_GT |
Guatemalan Spanish |
es_MX |
Mexican Spanish |
es_NI |
Nicaraguan Spanish |
es_PA |
Panamanian Spanish |
es_PE |
Peruvian Spanish |
es_PY |
Paraguayan Spanish |
es_SV |
Salvadoran Spanish |
es_UY |
Uruguayan Spanish |
es_VE |
Venezuelan Spanish |
fr |
French |
fr_BE |
Belgian French |
fr_CA |
Canadian French |
fr_CH |
Swiss French |
it |
Italian |
ja |
Japanese |
ko |
Korean |
sv |
Swedish |
zh |
Chinese |
zh_TW |
Chinese Taiwan |
Note that the settings listed in the table are the ones that SunPCi supports; it does not list all the languages Solaris supports.
