Sun Java System Directory Server Enterprise Edition 6.3 Reference
Appendix A Directory Server Resource Kit File Reference
This appendix describes the files found after you install Directory Server Resource Kit. You can also find lists of installed files in the install-path/dsee6/data/ directory.
The examples shown in this appendix are for Solaris systems. File extensions and path separators may differ for your operating system.
Software Layout for Directory Server Resource Kit
This section describes the file layout you find after installing Directory Server Resource Kit from the zip distribution. All files locations are relative to the path where you installed the product. For information on default native package installation locations, see Default Paths and Command Locations.
install-path/dsee6/
Files shared by multiple Directory Server Enterprise Edition component products. This directory houses the following files of interest.
install-path/dsee6/bin/certutil
NSS certificate manipulation command used by other tools, not intended to be used directly.
install-path/dsee6/bin/dsee_deploy
Command to install and remove software. See dsee_deploy(1M).
install-path/dsee6/bin/ldif
Command to base64 encode LDIF attribute values. See ldif(1)
install-path/dsee6/cacao_2.0/
Common agent container files shared by Directory Server Enterprise Edition component products, not intended to be used directly.
Lists of installed files used by the dsee_deploy command, not intended to be used directly.
install-path/dsee6/lib/
Libraries shared by Directory Server Enterprise Edition component products, not intended to be used directly.
install-path/dsee6/man/
Directory Server Enterprise Edition online reference manual pages. See also Sun Java System Directory Server Enterprise Edition 6.3 Man Page Reference.
install-path/dsrk6/bin/authrate
Directory Server Resource Kit command to measure authentication rate. See authrate(1).
install-path/dsrk6/bin/dsmlmodify
Directory Server Resource Kit command to update entries using DSML v2. See dsmlmodify(1).
install-path/dsrk6/bin/dsmlsearch
Directory Server Resource Kit command to search a directory using DSML v2. See dsmlsearch(1).
install-path/dsrk6/bin/example_files/
Sample template files for use with the makeldif.
install-path/dsrk6/bin/ldapcmp
Directory Server Resource Kit command to compare LDAP entries from two directories. See ldapcmp(1).
install-path/dsrk6/bin/ldapcompare
Directory Server Resource Kit command to perform LDAP compare operations. See ldapcompare(1).
install-path/dsrk6/bin/ldapdelete
Directory Server Resource Kit command to delete directory entries. See ldapdelete(1).
install-path/dsrk6/bin/ldapmodify
Directory Server Resource Kit command to update entries over LDAP. See ldapmodify(1).
install-path/dsrk6/bin/ldappasswd
Directory Server Resource Kit command to change user passwords. See ldappasswd(1).
install-path/dsrk6/bin/ldapsearch
Directory Server Resource Kit command to search a directory. See ldapsearch(1).
install-path/dsrk6/bin/ldapsubtdel
Directory Server Resource Kit command to delete a directory subtree recursively. See ldapsubtdel(1).
install-path/dsrk6/bin/ldifxform
Directory Server Resource Kit command to transform LDIF content. See ldifxform(1).
install-path/dsrk6/bin/logconv
Directory Server Resource Kit command to analyze Directory Server access logs. See logconv(1).
install-path/dsrk6/bin/makeldif
Directory Server Resource Kit command to generate LDIF content for testing and benchmarking purposes. See makeldif(1).
install-path/dsrk6/bin/modrate
Directory Server Resource Kit command to measure rates of modifications to directory entries. See modrate(1).
install-path/dsrk6/bin/searchrate
Directory Server Resource Kit command to measure search rates. See searchrate(1).
install-path/dsrk6/class/
Libraries used by Directory Server Resource Kit commands, not intended to be used directly.
install-path/dsrk6/lib/
