NAME | Description | Attributes | See Also
Syntax |
duration |
Default value |
10000 |
Must be set |
No |
Is modifiable |
Yes |
Is multivalued |
No |
Requires restart |
No |
This property specifies the maximum length of time that a connection between Directory Proxy Server and a data source is attempted before the connection attempt fails.
The duration is expressed in milliseconds.
This property is used to configure the following features:
The common name of the LDAP data source
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Availability |
SUNWldap-proxy |
Stability Level |
Evolving |
dpconf(1M)
