NAME | Description | Attributes | See Also
Syntax |
boolean |
Default value |
false |
Must be set |
No |
Is modifiable |
No |
Is multivalued |
No |
Requires restart |
No |
This property is a flag indicating whether Directory Proxy Server must be restarted in order for configuration changes to take effect.
This property is true or false.
This property is used to configure the following features:
The global configuration of Directory Proxy Server contains properties that affect the overall operation of Directory Proxy Server.
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Availability |
SUNWldap-proxy |
Stability Level |
Evolving |
dpconf(1M)
