NAME | Description | Attributes | See Also
Syntax |
boolean |
Default value |
false |
Must be set |
No |
Is modifiable |
Yes |
Is multivalued |
No |
Requires restart |
No |
This property specifies whether Server uses "filter-join-rule" and "dn-join-rule" property values stored on join views.
This property is true or false.
This property is used to configure the following features:
A join data view is an aggregation of multiple data views. The current release of Directory Proxy Server supports the aggregation of two data views into one join data view.
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Availability |
SUNWldap-proxy |
Stability Level |
Evolving |
dpconf(1M)
