NAME | Description | Attributes | See Also
Syntax |
accessLogLevel |
Default value |
inherited |
Must be set |
No |
Is modifiable |
Yes |
Is multivalued |
No |
Requires restart |
No |
This property specifies the log level for events related to connection handlers.
This property can take the following values.
All messages are included in the log file. In most cases, this setting produces the same results as the info setting. In certain situations, this setting enables additional debugging messages to be logged.
Errors, warnings and informational messages are included in the log file.
The log level is inherited from the value of the default-log-level property.
No messages are included in the log file.
This property is used to configure the following features:
The access log contains information about the requests being processed by the Directory Proxy Server.
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Availability |
SUNWldap-proxy |
Stability Level |
Evolving |
dpconf(1M)
